  3. What’s Inside the GUI-Based Timing Report in Genus? Want…
Neha Joshi
Neha Joshi
report
Genus
gui
timing debug
Timing Optimization
debug report
Synthesis
What’s Inside the GUI-Based Timing Report in Genus? Want to Explore?
6 May 2021 • 1 minute read
Timing closure is one of the most crucial steps of a digital design. Therefore, to meet timing at the later stages of design signoff, it is imperative to consider timing analysis within the synthesis stage.
We know real designs are complex, and so is the timing analysis. Unfortunately, we cannot reduce the complexity, but we can make the ride smooth during the timing analysis journey!!
The trick is to use a GUI-based timing report!
The Genus Synthesis Solution's GUI (Graphical User Interface) helps you analyze/debug the timing issues/results using GUI capabilities.
Are you ready to tour the GUI world to:
  • See the timing path in the layout viewer?
  • Identify the attributes associated with various pins of the timing path?
  • Explore timing path relation with the design browser?
  • Analyze the failing paths?
To explore more about these common questions that might arise while investigating the timing report, refer to the latest video on https://support.cadence.com [Cadence login required]. This video shows how to analyze the timing report in Genus Synthesis Solution GUI.
Video Title: Analyzing GUI-Based Timing Report in Genus (Video)
 Direct Link: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AGz9DEAT&pageName=ArticleContent
Related Resources:
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
