  3. All I Really Need to Know About MDV I Learned From Hollywood…
tomacadence
tomacadence
vPlan
verification planning
metric-driven verification
Hollywood
MDV
IP modeling
verification
All I Really Need to Know About MDV I Learned From Hollywood - Part 3
14 Sep 2010 • 3 minute read
This is my third and final blog entry in a series using quotes from famous Hollywood movies to highlight the key concepts about metric-driven verification (MDV). As a reminder, here's the four-phase Cadence MDV flow:
In my first post I dealt with the "plan" phase and the concept of planning for both coverage and check metrics from the very beginning of a project. In my second post I discussed the "construct" phase, in which the verification environment is built and the detailed metrics are defined. This same post also covered the "run" phase, during which the metrics are actually generated by multiple engines. Finally, I come to the "measure and analyze" phase, which includes determining whether or not verification is complete enough for front-end signoff.
The "run" phase generates lots of metric data, typically many gigabytes, and so the final phase must provide a way to compile, compact, abstract and analyze the data efficiently. For most of the project duration, verification engineers hope that a weakness (failing check) is found during this analysis, since this indicates a bug in the design or verification environment. It is common for the verification manager to generate a "bug rate" chart showing the number of bugs found per week on the project thus far. With an MDV flow, such a chart will usually show a rapid ramp-up in bug discovery during the early portion of the project, a busy peak period, and then a slow tail-off as there are fewer and fewer bugs being discovered.
Reaching the point at which new bugs are being found at a very slow rate (say, one per week) is typically one of the signoff criteria for the verification lead. Checks by themselves are not sufficient, since it is possible that the verification environment is simply not exercising the portions of the design still containing bugs. Coverage metrics help to solve this problem by showing areas of the design not being sufficiently verified, another form of weakness. Ultimately, what the verification team wants is for all the coverage points to be reached while all the checks are turned on and reporting no failures.
Of course, limitations in the verification environment may prevent all the coverage points from being reached. In this case, the verification engineers might re-examine the verification plan to see if all the metrics were properly specified. If a particular coverage point seems impossible to reach in simulation, they might use formal analysis to see whether it's possible to reach it at all. Simple coding errors sometimes isolate sections of the design so that the logic is unreachable, and only formal analysis can detect this.
On the other hand, if formal analysis can reach the coverage point, its trace can be very helpful in hitting that same point in simulation. Alternatively, the verification team might be happy to let formal "take credit" for hitting the coverage point and marking it as done. For any coverage points not yet resolved, the team goes through another iteration of the MDV loop, possibly tweaking the verification plan or the environment or perhaps just running more constrained-random tests.
Eventually, the verification progress will converge so that the achieved coverage has reached or surpassed the project goals. At this point, the verification manager will declare success, and the project team will consider signing off on the front-end design and verification. The result should indeed be the "beginning of a beautiful friendship" between the verification team and Cadence MDV, in that future projects will fully embrace the principles and practices that have made MDV so successful on hundreds of chip projects.
This concludes my short blog series on the benefits of MDV as expressed by movie quotes. It's been fun writing these posts, and I hope that it's been enjoyable and diverting for you to read them. I had lots of ideas for quotes that I didn't use, but instead of sharing them I encourage you to post some comments with your suggestions. Let's make this a dialogue instead of a one-way communication!
Tom A.
The truth is out there...sometimes it's in a blog.
