  3. C-to-Silicon Compiler Launch
Ran Avinun
Ran Avinun
high-level synthesis adoption
14 Jul 2008 • 1 minute read
On July 14th, Cadence introduced C-to-Silicon Compiler, a next-generation high-level synthesis product that improves designer productivity up to 10x in creating and re-using system-on-chip IP.  C-to-Silicon Compiler enables engineers to design at a higher level of abstraction and helps automate the analysis of hardware micro-architecture.
C-to-Silicon Compiler automatically translates and optimizes abstract behavioral descriptions from C/C++ /SystemC to synthesizeable Verilog RTL for implementation, verification and SoC integration.
C-to-Silicon Compiler addresses all the major barriers to high-level synthesis adoption:
  • Embedded Logic Synthesis (ELS) Uses embedded RTL-Compiler for high-accuracy timing estimates that enable parallel optimization of control and datapath logic, and delivering better-than-average human QoR.
  • Behavior-Structure-Timing (BST) database that enables “true” incremental synthesis, avoiding the need to repeat synthesis and verification each time an incremental design-change is made.
  • Constraint-Functionality Separation (CFS) enables easy design-re targeting across multiple applications as well process-technologies
  • Auto-generated Fast Hardware Model (FHM) to accelerate verification and enable HW-SW co-development
If you have an opinion about this annoucement, please share it within this blog below. If you want to hear about other opinions, go to the following links to see what the press wrote about this.
  •  http://www.edn.com/blog/1690000169/post/230029823.htm
  • http://www.eetimes.com/news/design/showArticle.jhtml?articleID=209000108
  •  http://scdsource.com/article.php?id=270http://electronicdesign.com/Articles/ArticleID/19361/19361.html
