  3. Deferrable Memory Write Usage and Verification Challeng…
Satish Kumar C
Satish Kumar C
CXL
PCIe
PCIe Gen5
Deferrable memory write transaction
Deferrable Memory Write Usage and Verification Challenges
17 Oct 2024 • 6 minute read
The application of real-time data processing or responsiveness is crucial, such as in high-performance computing, data centers, or applications requiring low-latency data transfers. It enables efficient use of PCIe bandwidth and resources by intelligently managing memory write operations based on system dynamics and workload priorities. By effectively leveraging Deferrable Memory Write [DMWr], Devices can achieve optimized performance and responsiveness, aligning with the evolving demands of modern computing applications.
What Is Deferrable Memory Write?
Deferrable Memory Write (DMWr) ECN introduced this new memory transaction type, which was later officially incorporated in PCIe 5.0 to CXL2.0. This enhanced type of memory transaction is Deferrable Memory Write [DMWr], which flows as another type of existing Read/Write memory transaction; the major difference of this Deferrable Memory Write, where the Requester attempts to write to a given location in Memory Space using the non-posted DMWr TLP Type, it Postponing their completion of memory write transactions to improve overall system efficiency and performance, those memory write operation can be delay or deferred until other priority task complete.
The Deferrable Memory Write (DMWr) requires the Completer to return an acknowledgment to the Requester and provides a mechanism for the recipient to defer (temporarily refuse to service) the Request.
DMWr provides a mechanism for Endpoints and hosts to choose to carry out or defer incoming DMWr Requests. This mechanism can be used by Endpoints and Hosts to simplify the design of flow control, reduce latency, and improve throughput. The Deferrable Memory writes TLP format in Figure A.
(Fig A) Deferrable Memory writes TLP format.
Example Scenario
Here's how the DMWr works with a simplified example: Imagine a system with an endpoint device (Device A) and a host CPU (Device B). Device B wants to write data to Device A's memory, but due to varying reasons such as system bus congestion or prioritization of other transactions, Device A can defer the completion of the memory write request. Just follow these steps:
  1. Initiation of Memory Write: Device B initiates a memory write transaction to Device A. This involves sending the memory write request along with the data payload over the PCIe physical layer link.
  2. Acknowledgment and Deferral: Upon receiving the memory write request, Device A acknowledges the transaction but may decide to defer its completion. Device A sends an acknowledgment (ACK) back to Device B, indicating it has received the data and intends to complete the write operation but not immediately.
  3. Deferred Completion: Device A defers the completion of the memory write operation to a later, more opportune time. This deferral allows Device A to prioritize other transactions or optimize the use of system resources, such as memory bandwidth or processor availability.
  4. Completion and Response: At a later point, Device A completes the deferred memory write operation and sends a completion indication back to Device B. This completion typically includes any status updates or additional information related to the transaction.
Usage or Importance of DMWr
Deferrable Memory Write usage provides the improvement in the following aspects:
  • Reduced Latency: By deferring less critical memory write operations, more critical transactions can be processed with lower latency, improving overall system responsiveness.
  • Improved Efficiency: Optimizes the utilization of system resources such as memory bandwidth and CPU cycles, enhancing the efficiency of data transfers within the PCIe architecture.
  • Enhanced Performance: Allows devices to manage and prioritize transactions dynamically, potentially increasing overall system throughput and reducing contention.
Challenges in the Implementation of DMWr Transactions
The implementation of deferrable memory writes (DMWr) introduces several advancements and challenges in terms of usage and verification:
  1. Timing and Synchronization: DMWr allows transactions to be deferred, complicating timing requirements or completing them within acceptable timing windows to avoid protocol violations. Ensuring proper synchronization between devices becomes critical to prevent data loss or corruption.
  2. Protocol Compliance: Verification must ensure compliance with ECN PCIe 6.0 and CXL specifications regarding when and how DMWr transactions can be initiated and completed.
  3. Performance Optimization: While DMWr can improve overall system performance by reducing latency, verifying its impact on system performance and ensuring it meets expected benchmarks is crucial.
  4. Error Handling: Handling errors related to deferred transactions adds complexity. Verifying error detection and recovery mechanisms under various scenarios (e.g., timeout during deferral) is essential.
Verification Challenges of DMWr Transactions
The challenges to verifying the DMWr transaction consist of all checks with respect to Function, Timing, Protocol compliance, improvement, Error scenario, and security usage on purpose, as well as Data integrity at the PCIe and CXL.
  1. Functional Verification: Verifying the correct implementation of DMWr at both ends of the PCIe link (transmitter and receiver) to ensure proper functionality and adherence to specifications.
  2. Timing Verification: Validating timing constraints associated with deferring writes and ensuring transactions are completed within specified windows without violating protocol rules.
  3. Protocol Compliance Verification: Checking that DMWr transactions adhere to PCIe and CXL protocol rules, including ordering rules and any restrictions on deferral based on the transaction type.
  4. Performance Verification: Assessing the impact of DMWr on overall system performance, including latency reduction and bandwidth utilization, through simulation and testing.
  5. Error Scenario Verification: Creating and testing scenarios to verify error handling mechanisms related to DMWr, such as timeouts, retries, and recovery procedures.
  6. Security Considerations: Assessing potential security vulnerabilities related to DMWr, such as data integrity risks during deferred transactions or exposure to timing-based attacks.
Major verification challenges and approaches are timing and synchronization verification in the context of implementing deferrable memory writes (DMWr), which is crucial due to the inherent complexities introduced by deferred transactions. Here are the key issues and approaches to address them:
Timing and Synchronization Issues
  1. Transaction Completion Timing:
    • Issue: Ensuring deferred transactions are completed within the specified time window without violating protocol timing constraints.
    • Approach: Design an internal timer and checker to model worst-case scenarios where transactions are deferred and verify that they are complete within allowable latency limits. This involves simulating various traffic loads and conditions to assess timing under different scenarios.
  2. Ordering and Dependencies:
    • Issue: Verifying that transactions deferred using DMWr maintain the correct ordering and dependencies relative to non-deferred transactions.
    • Approach: Implement test scenarios that include mixed traffic of DMWr and non-DMWr transactions. Verify through simulation or emulation that dependencies and ordering requirements are correctly maintained across the PCIe link.
  3. Interrupt Handling and Response Times:
    • Issue: Verify the handling of interrupts and ensure timely responses from devices involved in DMWr transactions.
    • Approach: Implement test cases that simulate interrupt generation during DMWr transactions. Measure and verify the response times to interrupts to ensure they meet system latency requirements.
In conclusion, while deferrable memory writes in PCIe and CXL offer significant performance benefits, their implementation and verification present several challenges related to timing, protocol compliance, performance optimization, and error handling. Addressing these challenges requires rigorous testing and testbench of traffic, advanced verification methodologies, and a thorough understanding of PCIe specifications and also the motivation behind introducing this Deferrable Write is effectively used in the CXL further. Outcomes of Deferrable Memory Write verify that the performance benefits of DMWr (reduced latency, improved throughput) are achieved without compromising timing integrity or violating protocol specifications.
In summary, PCIe and CXL are complex protocols with many verification challenges. You must understand many new Spec changes and consider the robust verification plan for the new features and backward compatible tests impacted by new features. Cadence's PCIe 6.0 Verification IP is fully compliant with the latest PCIe Express 6.0 specifications and provides an effective and efficient way to verify the components interfacing with the PCIe 6.0 interface. Cadence VIP for PCIe 6.0 provides exhaustive verification of PCIe-based IP and SoCs, and we are working with Early Adopter customers to speed up every verification stage.
More Information
  • For more info on how Cadence PCIe Verification IP and TripleCheck VIP enable users to confidently verify PCIe 6.0, see our VIP for PCI Express, VIP for Compute Express Link, and TripleCheck for PCI Express
  • See the PCI-SIG website for more details on PCIe in general and the different PCI standards.
