  3. e Templates: A Nifty Way To Create Reusable Code
teamspecman
teamspecman
IEEE 1647
funtional verification
when sub-typing
TLM
Verification methodology
Object Oriented Programming
innovation
Open Verification Methodology
when inheritance
Testbench simulation
OVM e
Coverage-Driven Verification
e
OVM-e
team specman
specman elite
OOP
coverage driven verification (CDV)
ClubT
Aspect Oriented Programming
esl tlm synthesis rtl dac estimation planning
macros
eRM
System Verification
hvl
IES
Coverage Driven Verification
Functional Verificatioa
OVMWorld
verification
IES-XL
Trailblazer
10 Aug 2010 • 1 minute read
Hi All,
An e template (known as a parameterized type in other programming languages) is a feature that has been around for several releases and can be a great way of creating re-usable code.  Templates can be used anywhere a user would like to create a single re-useable object that might operate on different data types.  An example would be to create a scoreboard (if you were not already using the ovm_scbd package) that can be instantiated to perform checking on packets, transactions, or any other type of data structure of interest.
Below is a short example of a simple FIFO scoreboard implemented using a template:
File: scoreboard.e
template unit scoreboard of (<T'type>) {
    // Instantiate the TLM analysis ports to receive items for adding items to the scoreboard and checking
    add_pkt: in interface_port of tlm_analysis of <T'type> using prefix=add_pkt_ is instance;
    check_pkt: in interface_port of tlm_analysis of <T'type> using prefix=check_pkt_ is instance;
    // The actual scoreboard list
   !sblist: list of <T'type>;
   // Implement the _write() method of the TLM analysis port
   add_pkt_write(p: <T'type>) is {
      message(NONE, "scoreboard added item: ", p);
      sblist.push(p);
   check_pkt_write(p: <T'type>) is {
      if (deep_compare_physical(p, sblist[0], 10).is_empty()) then {sblist.delete(0);};
      message(NONE, "scoreboard checked item: ", p);
Using the above code, a user can instantiate the same scoreboard code to handle any type of data structure.
File: env.e
unit env_u {
   packet_sb: scoreboard of (packet_s) is instance;  // Scoreboard to handle packets
   transaction_sb: scoreboard of (transaction_s) is instance;  // Scoreboard to handle transactions
Hope this little technical tidbit helps.
Happy verifying!
Corey
