  3. e Templates and Aspect Oriented Programming
teamspecman
teamspecman
Specman
EDA
e
team specman
AOP
IES-XL
21 Sep 2010 • 2 minute read
In a recent blog - "e Templates: A Nifty Way To Create Reusable Code", Corey Goss wrote about the useful feature of template types, which lets you write reusable code.
In this post I'll show how the combination of templates and aspect-oriented programming (AOP) allows you to make such reusable code even more flexible. This combination is indeed unique for the e language. As you surely know, AOP allows you to extend an already existing struct or unit, and add or modify some of its members, for example add a new field or modify a method (with "is only" or "is also").
For templates, you can also extend a specific instance of an existing template. So, in this case AOP allows you not only to separate your struct into "aspects" (when the fields, methods, and events of each aspect can be defined in a different module), but also to use the same familiar "extend ..." syntax to distinguish between what is common to all instances and what is specific to a given instance.
Let's use the slightly modified example from Corey's post to illustrate this:
template unit scoreboard of (<T'type>) {
    // Instantiate the TLM analysis ports to receive items for adding items to the scoreboard and checking
    add_item: in interface_port of tlm_analysis of <T'type> using prefix=add_item_ is instance;
    check_item: in interface_port of tlm_analysis of <T'type> using prefix=check_item_ is instance;
    // The actual scoreboard list
   !sblist: list of <T'type>;
   // Implement the _write() method of the TLM analysis port
   add_item_write(p: <T'type>) is {
      message(NONE, "scoreboard added item: ", p);
      sblist.push(p);
   check_item_write(p: <T'type>) is {
      if (deep_compare_physical(p, sblist[0], 10).is_empty()) then {sblist.delete(0);};
      message(NONE, "scoreboard checked item: ", p);
Now suppose we want to slightly modify the behavior of scoreboard for a specific transaction type, say packets. It would preserve the same logic, but it would use a custom comparison method for packets. This can be done simply by adding the following code:
extend scoreboard of packet_s {
   check_item_write(p:  packet_s) is only {
      if (p.compare(sblist[0])) then {sblist.delete(0);};
In this example we have modified a method of a specific template instance, using "is only". You can also add fields, methods, or do any other change to a template instance, that you are used to do when extending a struct.
If you are familiar with template types in other languages, such as C++ or SystemVerilog, you may wonder whether this capability is different from the template specialization feature provided by some of those languages. The answer is yes. In C++ you can write a separate implementation for a specific template instance, but then you fully replace the generic code written for the template with the new code. In e, as we've just shown, you can keep the template code which is common for all instances, and make just additions or modifications (if any needed) for specific instances.
Yuri Tsoglin
Specman R&D e Language team.
