  3. Building Open Virtual Platforms - Bridging the Gap of Model…
Steve Brown
Steve Brown
TLM2
Virtual System Platform
IP
TLM
Models
virtual prototypes
virtual platform
TLM 2.0
System Development Suite
architectural
embedded software
VSP
Multi-Core
SystemC analysis
SystemC
Modeling
multicore
architect
Building Open Virtual Platforms - Bridging the Gap of Model Availability
4 May 2011 • 2 minute read
Virtual prototypes promise to enable early software development, shorten system bring-up time, and provide a resulting increase in revenue. One of the key barriers that project teams face when considering use of virtual prototypes is the "missing model syndrome" -- essentially the lack of adequate pre-built IP to assemble into the prototype, and the challenges of creating those models themselves. Some providers have created libraries of models, but without a standard language the models are proprietary and cannot be used in any other environment. The SystemC language (IEEE 1666) has added the important TLM 2.0 extensions, but writing models with TLM 2.0 requires practice and a methodology for reusability.
Cadence announced its new Virtual System Platform as part of the System Development Suite May 3. The Virtual System Platform enables pre-RTL software development, system functional verification, and system analysis and optimization before committing to a hardware micro-architecture. One of its key capabilities is its open modeling approach supporting processor models, and automating the creation of TLM 2.0 for interconnect and IP blocks. It incorporates high performance processor models from ARM, Imperas, and others that utilize SystemC TLM 2.0. What is new and valuable is the generation of TLM 2.0 code to speed the process of creating new virtual prototype models.
In order for models to be truly open and reusable, they must be written using SystemC TLM 2.0. The Virtual System Platform has TLM-aware capabilities that provides non-intrusive debugging and observability of the system behavior. Any TLM 1.0 or TLM 2.0 models will execute in the Virtual System Platform. It also comes with a TLM generation capability that uses a description of the pins and registers to generate all the TLM 2.0 interface code. As you can see from the process flow below, this code can be compiled and linked into a virtual prototype that can be used for early software compilation and simple register activity testing. Subsequently the function of each virtual prototype IP block can be added, in order to bring-up the operating system, such as Linux.
The TLM generation uses a textual or IP-XACT description of the interface pins and registers, and produces all the TLM 2.0 for the IP. This includes all the pin and register declarations, access functions, and C++ templates for implementing the functionality of the IP. Not only is this an open, standards based approach, but it provides an easy way to maintain the code as registers or pins are added, changed, or deleted. It also produces the header files needed for embedded software compilation, program files that test all the register read/write behavior, and the header files for integration with the rest of the virtual prototype.
There are other capabilities and benefits of the Virtual System Platform related to its connection to the rest of the System Development Suite, and its scalability for today's multi-core systems. Watch this space!
Steve Brown
