  3. Enabling OVM Transaction Debug in SimVision Without Code…
Team genIES
Team genIES
SystemVerilog
debug
simvision
OVM SV
OVM 2.0
IES
IES-XL
Enabling OVM Transaction Debug in SimVision Without Code Changes
11 Jun 2009 • 5 minute read
Are you tired of putting print statements in your code to do debug?  Do you work with designers who just want to use waveforms to debug testbench and design problems?
There is a cool feature in the OVM library and Incisive Enterprise Simulator that comes to the rescue.  It is the built-in OVM transaction recording.
Modern metric driven testbenches generate a lot of dynamic data on the fly during a simulation run.  The test and testbench combination is usually simulated with multiple random seeds to produce different sequences of transactions to maximize stimulus variation to the design.  When the checker catches an error, there is always the question.  Is it the design or the testbench?  The answer usually is, let's look at the waveforms to figure out if the testbench is doing the right thing.
Here you need a way to visualize and interact with the transaction stream without modifying your verification environment.  We want to get away from doing vector decodes to figure out that this packet is going to port  5 or this transaction is a read request over a serial interface.
Using OVM with the Incisive Enterprise Simulator gives you a built-in way to visualize sequences and transactions generated by OVM sequencer without writing any code!
Consider the following class called xbus_transfer representing a CPU transaction. The steps in the illustration highlight how transaction recording is automated via base class functionality and macros that implement virtual functions.
trans blog - xbus source
This xbus_transfer class is used to create sequences of transaction in a verification environment using ovm_sequencer base class.  Typical environments have a handful of random sequences that the user defines to capture interesting scenarios using constraints on transactions.  The user can use ovm_random_sequence to perform random selection of user defined sequences or specify their own weighting or specific sequence selection for a test.   The following example shows how transactions are automatically recorded during the simulation and their visualization by using SimVision waveform window; these transactions are from the bus master and use the ovm_random_sequence.
trans blog - SV window 1
From the above graphic, let's figure out what happened.
On the left you see the sequence hierarchy.  It shows that the top most sequence, also called the default_sequence is set as ovm_random_sequence for this test.  Upon expanding this stream (clicking on the plus sign in the left frame next to ovm_random_sequence), you can see what the ovm_random_sequence did during the simulation run.
In debug, it's helpful to correlate the sequence tree that ultimately creates the transaction so you can review the sequence code and adjust constraints if required.  For example, to see how the first random write occur, I can put the cursor in SimVision anywhere on the transaction and immediately understand that the WRITE of size 1 to address ‘hE539 was caused by the following sequence chain:
ovm_random_sequence
--> incr_read_write_seq
--> write0
--> write_byte_seq0
--> request WRITE, size=1, addr='hE539
Using the GUI, you can easily correlate the abstract transaction chain with transaction details, all by leveraging automation in the Incisive Enterprise Simulator and the OVM library.
How To Control Transaction Dumping in a Simulation
Transaction recording is controlled by setting "recording_detail" variable at the component level using the standard OVM configuration API.  You can control transaction dumping for any ovm_component or the derived class, through SystemVerilog test or IES TCL command. Remember the ovm_sequencer is a child of ovm_component.
Controlling recording_detail from IES TCL Command
trans blog - forms
The two above examples show different ways to enable the transaction recording:
  • The first one turns on transaction recording for the specific component hierarchy "ovm_test_top.xbus_demo_tb0.xbus0.masters[0].*"
This includes all subcomponents under masters[0] instance.
The second command uses the wildcard "*" to enable transaction recording for ALL components in the testbench.  Wildcarding is very convenient to affect large portions of the design with a single command.  However, care should be taken when using it in a large verification environment because it may create a lot of waveform data affecting simulation performance.
To turn transaction recording off using TCL, use OVM_NONE in place of OVM_FULL as value of recording_detail.
This command can also be used during the run to capture transactions in a time-window desirable for bug analysis.
Controlling recording_detail from SystemVerilog Test
You can use standard OVM configuration mechanism from your test's build method to control transaction recording dumping as follows:
trans blog - xbus source 2
Once transaction recording is enabled in a simulation, transactions can be viewed by loading the waves.shm database in SimVision interactively or in post-processing mode by selecting the appropriate component from the testbench hierarchy and sending it to the waveform viewer as shown below.
trans blog - SV Source Browse
Some Practical Considerations
  1. Incisive Enterprise Simulator and the OVM library ensure that changing "recording_detail" of a component doesn't affect random values.  This way a failing random simulation from a regression run can be rerun with the same random seed value with transaction recording, signal probes and high message verbosity to speed up failure analysis.
  2. TCL api provides a better alternate to control transaction recording vs. the SystemVerilog build() function because:
    •   TCL doesn't require recompilation, any change to SystemVerilog test does.
    •   TCL can be used to enable recording in a time window to speed up debug simulations
  3. You need to use the OVM library distributed with Incisive Enterprise Simulator to take advantage of automatic transaction recording and TCL API.
    Simply use "-ovm" switch with the irun script to pick up the OVM library with transaction recording hooks into SimVision and OVM TCLcommands.
  4. Transaction recording can be used in more applications such as displaying transactions collected by monitor, showing cause and effect by linking transactions traversing the design, and more.
 For more information, see:
  • xbus example distributed with the OVM library
  • OVM Class Reference Manual, Component Hierarchy, Transaction Recording under <IUS install>/doc/ovm_ref
  • OVM User Guide, XBUS OVC example under <KITSOCV install>/doc/ovm_guide
  • OVM User Guide, OVM TCL Commands under <KITSOCV install>/doc/ovm_guide
 NOTE: You can download KITSOCV and IES tools from downloads.cadence.com
 If you have any questions, feel free to post a comment or email genIES@cadence.com.
=Team genIES
