  3. Verification of the Lane Adapter FSM of a USB4 Router Design…
Neelabh
Neelabh
Verification IP
DP
VIP
DisplayPort
PCIExpress
USB
Lane Adapter
usb4
PCIe
usb4 router
tunneling
Verification of the Lane Adapter FSM of a USB4 Router Design Is Not Simple
10 Feb 2020 • 1 minute read
Verifying lane adapter state machine in a router design is quite an involved task and needs verification from several aspects including that for its link training functionality.
The diagram below shows two lane adapters connected to each other and each going through the link training process. Each training sub-state transition is contingent on conditions for both transmission and reception of relevant ordered sets needed for a transition. Until conditions for both are satisfied an adapter cannot transition to the next training sub-state.
As deduced from the lane adapter state machine section of USB4 specification, the reception condition for the next training sub-state transition is less strict than that of the transmission condition. For ex., for LOCK1 to LOCK2 transition, the reception condition requires only two SLOS symbols in a row being detected, while the transmission condition requires at least four complete SLOS1 ordered sets to be sent.
From the above conditions in the specification, it is a possibility that a lane adapter A may detect the two SLOS or TS ordered sets, being sent by the lane adapter B on the other end, in the very beginning as soon as it starts transmitting its own SLOS or TS ordered sets. On the other hand, it is also a possibility that these SLOS or TS ordered sets are not yet detected by lane adapter A even when it has met the condition of sending minimum number of SLOS or TS ordered sets.
In such a case, lane adapter A, even though it has satisfied the transmission condition cannot transition to the next sub-state because the reception condition is not yet met. Hence lane adapter A must first wait for the required number of ordered sets to be detected by it before it can go to the next sub-state. But this wait cannot be endless as there are timeouts defined in the specification, after which the training process may be re-attempted.
This interlocked way of operation also ensures that state machine of a lane adapter does not go out of sync with that of the other lane adapter. Such type of scenarios can occur whenever lane adapter state machine transitions to the training state from other states.
Cadence has a mature Verification IP solution for the verification of various aspects of the logical layer of a USB4 router design, with verification capabilities provided to do a comprehensive verification of it.
