  3. MIPI M‑PHY v6.0: Evolution of ADAPT for Ultra‑High‑Speed…
Sugandha Bansal
Sugandha Bansal
Verification IP
MIPI Alliance
VIP
MIPI
MPHY
MIPI M‑PHY v6.0: Evolution of ADAPT for Ultra‑High‑Speed Interfaces
22 Jul 2026 • 3 minute read
MIPI M-PHY has evolved to support higher data rates with the introduction of HS-G4 and beyond. This has created signal integrity challenges such as Inter-Symbol Interference (ISI), channel loss, and noise. To ensure reliable communication over these high-speed links, the ADAPT (Adaptive Equalization Training) feature was introduced in M-PHY. ADAPT is a training mechanism that enables us to analyze channel characteristics and refine its equalization settings before high-speed data transmission begins.
ADAPT works by transmitting a known training pattern from the transmitter to the receiver. Using this pattern, the receiver can tune its equalizer to compensate for channel impairments and improve the quality of received data. This process reduces bit errors, increases signal robustness, and enhances interoperability between devices operating at high data rates.
Originally introduced in M-PHY v4.1 for HS-G4, ADAPT continues to be used in HS-G5 and HS-G6. In M-PHY v6.0, where PAM-4 signaling is used with HS-G6 having 46.7 Gbps speed per lane, ADAPT becomes even more critical to maintain reliable link performance under increasingly challenging channel conditions.
Key Enhancements in M-PHY v6.0
In earlier M-PHY versions, ADAPT was defined only for HS-G4 and HS-G5 NRZ operation. With M-PHY v6.0, the ADAPT mechanism extends to support HS-G6 PAM4 signaling, where each symbol carries two bits of information. The eye openings for PAM-4 are significantly smaller than in NRZ signaling. This increases susceptibility to channel impairments, noise, and ISI, making equalization training far more critical. The enhanced ADAPT process with different pattern sequences enables the receiver to accurately characterize channel behavior and establish optimal operating parameters before data transmission, ensuring reliable communication at speeds up to 46.7 Gbps per lane.
M-PHY v6.0 introduces Transmitter Equalization, enabling the transmitter to pre-condition the signal before transmission using techniques such as pre-emphasis and de-emphasis. It helps to compensate for frequency-dependent channel losses at the source and preserves signal quality as it propagates through the channel. During link training, optimal transmitter equalization settings can be selected based on channel characteristics, maximizing eye opening, and improving data recovery at the receiver. When combined with receiver equalization, Tx EQ provides an end-to-end signal integrity solution that enables robust and reliable operation at ultra-high PAM4 data rates.
Aspect
HS-G4/G5
HS-G6
Encoding
8b10b
PAM-4 (1b1b)
Pattern
MK0 + PRBS9 (511+1 bits)
PRBS9 + PRBS15
Total Length
650 bits (65 symbols × 10)
512 + 32768 symbols
Polynomial
X⁹ + X⁵ + 1
X⁹ + X⁵ + 1 & X¹⁵ + X¹⁴ + 1
Phases
Single phase
Two phases (L0_L3, L0_L1_L2_L3)
Levels
2 (NRZ)
4 (PAM-4)
In conclusion, ADAPT plays a critical role in enabling reliable high‑speed operation in M‑PHY by ensuring robust link establishment even over challenging channel conditions. Through well‑designed training patterns, precise timing control, and coordinated protocol mechanisms, it supports signal integrity and stability at advanced data rates like HS‑G6. At the same time, its design preserves backward compatibility, ensuring seamless operation across both legacy and newer speed grades.
With the availability of the Cadence Verification IP for M-PHY, adopters can start working with these specifications immediately, ensuring compliance with the standard and achieving the fastest path to IP and SoC verification closure. Incorporating the latest protocol updates, the mature and comprehensive Cadence Verification IP (VIP) for the M-PHY protocol provides a complete bus functional model (BFM), integrated automatic protocol checks, and coverage model. Designed for easy integration into testbenches at IP, system-on-chip (SoC), and system levels, the VIP for M-PHY helps you reduce the time to evaluate, accelerate verification closure, and ensure end-product quality.
Learn more at Simulation VIP for MIPI M-PHY product page or reach out to Cadence's Verification IP experts.
