  3. New Specman Coverage Engine (Part III)—Use of Extension…
teamspecman
teamspecman
AF
e language
Funcional Verification
coverage driven verification (CDV)
Aspect Oriented Programming
New Specman Coverage Engine (Part III)—Use of Extension Under "when" vs. Using Instance-Based Options
25 Jul 2013 • 2 minute read
In both previous coverage blog posts (Part I and the Part II), we showed two solutions for refining instance-based coverage in a reusable way. And in doing so, we demonstrated a case where using the instance_ignore option is more suitable than using the extension under when solution.
Now, let us modify the requirement a little, by adding a new item to the covergroup:
extend packet_generator{
  cover packet_generated is also{
     item p_length: uint(bits:4) = cur_packet.length;
The length of the packet depends on the value of the size field according to the following constraints:
extend packet{
    length: uint(bits:4);
    keep size == SMALL => length in [0..2];
    keep size == MEDIUM => length in [3..6];
    keep size == LARGE => length in [7..10];
    keep size == HUGE => length in [11..15];
So again, for each packet_generator, some of the higher length values might be irrelevant due to the max_packet_size constraint.
We can set the ignored values using either of the following techniques:
  • Using the instance_ignore option:
   item p_length using also instance_ignore =
            (((inst.max_packet_size == SMALL) and (p_length > 2)) or
             ((inst.max_packet_size == MEDIUM) and (p_length > 6)) or
             ((inst.max_packet_size == LARGE) and (p_length > 10)));
  • Or by extending the covergroup under subtypes:
when SMALL'max_packet_size packet_generator{
      item p_length using also ignore = (p_length > 2);
when MEDIUM'max_packet_size packet_generator{
      item p_length using also ignore = (p_length > 6);
when BIG'max_packet_size packet_generator{
      item p_length using also ignore = (p_length > 10);
Here we recommend using the extension under when subtype code (the second bulleted option above), since the ignore expressions that need to be evaluated with this code are much simpler than the instance_ignore expression.
In some cases, only one of the solutions can be used:
  • A different setting of one of the other coverage options (for example weight) for each instance can only be achieved by extending the covergroup under when.
For example, if we want to have a larger weight for packet generators that can generate any size of packet, we need to add the following code:
when HUGE'max_packet_size packet_generator{
   cover packet_generated using also weight=2;
  • On the other hand, when collecting a covergroup under instances of a unit that is not the definition type of the covergroup (using the per_unit_instance=<other_type> group option), extending the under when subtype cannot be applied. In these cases, only the use of the instance-based options is possible.
For example, suppose that instead of defining the covergroup under the packet_generator unit, we would have defined it under the packet struct (but still collect it per instances of packet_generator):
extend packet{
     cover packet_generated using per_unit_instance=packet_generator is{
        item p_size: packet_size_t = cur_packet.size;
Now the covergroup can only be extended under the packet type, but we'd like to control the ignored values of its items according to a configuration field of packet_generator unit. So extension under when will not help us here.
But since instance-based options have a reference to the collection unit type (packet_generator) instance via the inst field, they can be used in the same manner that they are used when the covergroup is collected per instances of its declaration unit type.
Erez Bashi
