  3. New Specman Coverage Engine (Part II) - Using Instance-based…
teamspecman
teamspecman
AF
coverage parameterization
Specman
coverage
covergroups
instance-based coverage
subtypes
e language
extensions under subtypes
Funcional Verification
New Specman Coverage Engine (Part II) - Using Instance-based Coverage Options for Coverage Parameterization
23 Jul 2013 • 3 minute read
In the last coverage blog, we showed how the extensions of covergroups under when subtypes can help us write a reusable per-instance coverage.
We described a test case where a packet generator unit can create packets of different sizes. The packet generator unit has a field that describes the maximum size of any packet that can be generated by the packet_generator instance:
type packet_size_t: [SMALL, MEDIUM,LARGE,HUGE];
unit packet_generator{
    max_packet_size: packet_size_t;
    event packet_generated;
    cur_packet: packet;
    generate_packet() is{
        gen cur_packet keeping {it.size.as_a(int) <= max_packet_size.as_a(int)};
        emit packet_generated;
We defined a covergroup that is collected per each instance of packet_generator, to ensure that each packet generator creates packets of all relevant sizes:
extend  packet_generator{
     cover packet_generated using per_unit_instance is{
        item p_size: packet_size_t = cur_packet.size;
Then we refined the group's instances according to their actual subtypes, so that irrelevant packet sizes are ignored. This solution included setting a different fixed ignore condition for each subtype:
    when SMALL'max_packet_size packet_generator{
        cover packet_generated is also{
            item p_size using also ignore = p_size.as_a(int) >
                                         packet_size_t'SMALL.as_a(int);
    when MEDIUM'max_packet_size packet_generator{
packet_size_t'MEDIUM.as_a(int);
    // ... Same for other max_packet_size values
However, if we take a close look at the extensions under the subtypes, we can identify a uniform pattern for all the extensions:
                                         <max_packet_size field value of this subtype>
This pattern indicates that defining ignored values in a parameterized manner (that is, ignore all size values that are bigger than the value of the max_packet_size field of the instance) is more suitable here.
And as of Specman version 12.2, we have the appropriate syntax for doing exactly that:
       item p_size using also instance_ignore = p_size.as_a(int) >
                                         inst.max_packet_size.as_a(int);
The above code illustrates two new concepts: First, the use of the instance_ignore item option instead of the ignore option; second, the use of a special field named "inst" in the instance_ignore option.
Parameterized Instance-Based Coverage Options
In previous versions, Specman had four coverage options that defined what would be included in the coverage model:
-          no_collect group option – could be used to exclude groups / covergroup instances from the model.
-          no_collect item option –  could be used to exclude items from the model.
-          ignore / illegal items options – could be used to exclude specific buckets (bin) values from the model
In Specman 12.2, we added instance-based versions for these four coverage options:
-          instance_no_collect group option – for selectively refining which instance of the covergroup will be disabled.
-          instance_no_collect item option – for selectively refining from which group instance the item will be excluded.
-          instance_ignore /instance_ illegal items options – for selectively refining which item’s bucket will be under each coverage instance.
When using these instance based options, the user can use a special field, named ‘inst’, to reference the relevant unit instance of each coverage instance, and get the values of the configuration fields of the instance.
Specman assigns the value of the ‘inst’ field to the relevant unit instance, and then computes the expressions separately for each coverage instance.
As the above description indicates, the four instance-based options can be used to apply different behaviors to different instances of the same covergroup. But if there is a need to apply a common behavior for all instances of the covergroup, then the original “type based” options are more appropriate. For example, use the no_collect item option, not the instance_no_collect option, to remove base items of a cross item from the model.
Team Specman
