  3. OVM Multi-language Libraries – A Closer Look
Adam Sherer
Adam Sherer
SystemVerilog
OVM
VIP
OVM e
OVM SV
e
multi-language
SystemC
OVM SC
AOP
27 Feb 2009 • 2 minute read
Originally architected for multiple languages, the OVM is now available for all three standard languages used most commonly in verification SystemVerilog, e, and SystemC.  The e and SystemC libraries comply with the OVM 2.0.1 methodology and are available as open-source on OVM World.
All Languages in One Methodology - How?
The key to this all-for-one methodology is an architecture built from the ground-up for multiple languages.  Figure 1 shows the OVM Verification Component (OVC) "agent architecture." The OVC contains the monitor, sequencer, and driver which communicate among each other and outside of the OVC via a standard TLM channel.  This structure not only enables reuse both within the OVC and among multiple OVC, but it also enables multiple languages to be used because of the clearly defined, language independent APIs.
OVM Agent Architecture
Figure 1:  OVC Agent Architecture
The other key to the multi-language architecture is at the environment level as shown in Figure 2.  By hierarchically defining the configuration of the overall environment, the OVM can pass configuration information from the top-level in one language to OVCs below in another language.
OVM Environment
Figure 2:  Integrated OVM Environment with multiple OVCs
The architectural elements described here for multiple languages were in place for OVM 1.0 in January 2008.  The new libraries for OVM e and OVM SystemC now implement OVM in the other two IEEE standard languages used in modern verification environments.
OVM e - Addressing the Next Verification Challenges
Having introduced the agent architecture of the verification component in 2002, eRM users currently enjoy the same methodology as OVM SystemVerilog users.  With OVM e, users will get a new set of system level features in addition to the new features that align the library implementations to enable easier multi-language integration essentially making this the next eRM version.  Specifically, OVM e improves sequences, enhances performance, aligns base classes, aligns test flow phases, provides synchronization with SystemVerilog and SystemC, enables the ability to reconfigure VIP, and adds TLM ports.  These changes add to the eRM so that existing eRM environments become OVM environments and users can instrument their existing e-based VIP for use in multi-language verification environments.  Cadence has applied this technology itself so that both SystemVerilog and e users can take advantage of its portfolio of proven VIP.
OVM SystemC - Easing TLM Integration with the Verification Environment
SystemC use is growing in many projects as design teams move up in abstraction and seek better execution speed for the design under test.  The new OVM SystemC library aligns base classes, aligns test flow phases, and provides the TLM API to enable multi-language integration. The new OVM SystemC library also provides for multi-language configuration to enable the hierarchical assembly of the verification environment that enables the OVM to scale to system-level verification.
Learning More
This short blog only introduces the concept of the OVM multi-language libraries and the top technical features of the OVM e and OVM SystemC libraries.  The actual contribution on the OVM World contains much more details in the actual libraries and user manual. If you have any questions feel free to post them here, email them to ovm_contributions@cadence.com, or contact your local Cadence representative.  We will have more information available shortly in webinars and workshops so stay tuned to this blog for more on OVM for multiple verification languages.
=Adam Sheriblog
