  3. RAK Attack: Better Driver Tracing, Faster Palladium Build…
XTeam
XTeam
Rapid Adoption Kit
IXCOM
RAK
Indago
JasperGold
RAK Attack: Better Driver Tracing, Faster Palladium Build Time, UVM Register Map Automation
14 Mar 2020 • 2 minute read
Looking to learn? There's a bunch of new RAKs (Rapid Adoption Kits) available online now!
1) Indago 19.09 Better Driver Tracing and More
Are you new to Indago and not sure where to start? Luckily, there’s a new Rapid Adoption Kit for you: the Indago 19.09 Overview RAK! This neat package contains everything you need to get your debugging started through Indago. In four short labs, plus a brief introductory lab, you’ll have all the basics of Indago 19.09 down—the Indago working environment, the SmartLog, how Indago interacts with the rest of the Cadence Verification Suite, and how Indago uses HDL driver tracing.
Lab 1 discusses the various debugging tools included in Indago and teaches you how to customize your Indago windows and environment settings. Lab 2 covers the SmartLog feature and talks about analyzing and filtering its messages to suit your needs, as well as how to interact with the waveform marker. Lab 3 is an interactive Indago debugging experience—it’ll walk you through how to use Indago and its features in an actual working environment: setting breakpoints, using simulator commands in the Indago console, toolbars, switches, and more. Lab 4 is all things HDL tracing—recording debug data, an introduction to debug assertions, waveform visualizations, driving expression analysis, and single-step driver tracing, among other things.
Interested? Check out the RAK here.
2) IXCOM MSIE: Faster Palladium Build Time
Got several testbenches you want to compile with the same DUT and tests and you want to do it fast? With IXCOM, all you have to do to compile those different testbenches is use the xrun command for each after compiling your DUT. But what exactly is IXCOM, and how does one start using it? This quick RAK can help—here, you’ll learn the basics of using MSIE features with IXCOM, complete with an example to get you started. Using MSIE can vastly improve your build times with Palladium and using IXCOM is the best way to shrink that tedious rebuild time as small as it can get. Check out this RAK here.
3)  JasperGold Control and Status Register Verification App Automates UVM Register Map Verification
New to the JasperGold Control and Status Register (CSR) Verification App for your UVM testbenches? Don’t worry; there’s a RAK for that! This eponymous RAK can get you up and running with this in no time, helping you automate your checks from UVM register map specs. With this RAK, you’ll learn the basics of the JasperGold CSR, how to use JasperGold CSR’s Proof Accelerator, and more. CSR features a model-based approach to predicting a register’s expected value, supports pipeline interfaces, all IP-XACT access policies, and it can fully model any expected register value. It also supports register aliases, read and write semantics, and separate read/write data latencies in any given field.
If this functionality sounds up your alley, you can take a look at this RAK here.
