  3. Silicon Hive CTO: How Transaction-Based Acceleration Speeds…
Ran Avinun
Ran Avinun
IP
Leitjen
Acceleration
Silicon Hive
video
Palladium
SoC
Emulation
transaction-based
TBA
graphics
verification
Silicon Hive CTO: How Transaction-Based Acceleration Speeds IP Verification And Prevents TV "Crashes"
2 Aug 2010 • 7 minute read
 Jeroen Leijten is Chief Technology Officer for Silicon Hive, a Dutch company that has quickly become one of the world's leading intellectual property (IP) providers of imaging and video processing solutions for rapidly changing market segments such as connected, interactive digital televisions and smart phones.  Silicon Hive programmable parallel system solutions are licensed by semiconductor companies such as Samsung, LSI and Intel.  Silicon Hive engineers recently implemented a use model called"transaction-based acceleration" (TBA) with the Cadence Palladium III accelerator/emulator to verify some of Silicon Hive's most advanced multimedia system IP solutions (including hardware and software).  Jeroen recently sat down to talk with us about his team's work.
Q:  Jeroen, can you tell us more about Silicon Hive?
A: Silicon Hive is a worldwide, independent supplier of semiconductor intellectual property. Our company designs, builds and licenses application-specific system solutions for imaging, video processing and communications using our programmable HiveFlex parallel processor cores, complete vertical HiveGo imaging and video system solutions, and HiveLogic platform. HiveLogic and HiveGo system solutions are supported by HiveCC programming development tools, and by partner-supplied application libraries provided by Silicon Hive and its partners.
Our products enable semiconductor and consumer electronics companies to create and integrate fully programmable SoCs, thus improving time to market performance. As we develop our products, we maintain full programmability and field-upgradeability within the cost and power constraints required in our target market segments.
Our patented technology originates from 10 years of research and development within Philips Research Laboratories. Silicon Hive spun out of Philips in 2007.
Q: What markets is Silicon Hive going after today?
A: Our HiveGo VSS (Video System Solutions) aim at the digital televison (HDTV) market, while HiveGo CSS Camera Sub-Systems Solutions are focused on smart phones and multimedia phones.   We are one of the very few companies who can deliver the complete image processing chain all the way from sensor to codec, including all the software.  Our solutions deliver up to 20 million pixels resolution up to 30 frames per second.
We also license our HiveFlex processors standalone together with all the necessary software development tools. However, interestingly, customers today are asking for this less often, preferring full HiveGo system solutions where Silicon Hive and its customers customize and integrate customer's proprietary software.
HiveGo CSS imaging solutions are used in wireless handsets. When you consider that more than one billion mobile phones are sold each year, and a rapidly increasing share of these now contain some sort of camera, you start to understand the market potential here. The Digital HDTV market, Internet digital video and connectivity are changing the functional requirements rapidly.  The inherent flexibility of our architecture is a big advantage in this market for us, because Internet video codec standards continue to evolve rapidly, changing as frequently as every three months. This really requires software programmability.
Q: What do you see as the critical requirements in order for Silicon Hive to win in the digital TV market?
A: Like most consumer applications, cost is perhaps the most important, but also quality and performance.  Our customers, including OEMs like Samsung and Intel, mandate an extremely low failure rate for the final consumer products.  The warranty cost otherwise would be prohibitive.  This is totally another level of quality compared to, say, a PC.  While a television has become a computer in itself, unlike with a PC, consumers will not accept a TV "crashing" and having to "reboot."
However, this kind of problem is difficult to prevent.  In order to achieve this, one must build in capabilities for error resilience and error recovery so the TV gracefully recovers from any system errors and does not crash.  Obviously, all of this requires a lot of stress testing and verification of the system under a wide set of conditions.
Q: Can you tell us more about the verification challenges with Hive Go systems?
A: HiveGo products are complex hardware and software system solutions with four or five internal buses, multiple arbiters hooking up to multiple processors, and large memories.  The challenge is that you have to verify all the blocks will work together properly in the system.
Of course, first you verify blocks working separately, but that is only the starting point.  Then you must do system stress testing.  The most difficult bugs are those resulting from interaction between blocks, such as corner cases, pipeline stalls, and overflowing buffers, which are almost impossible to predict ahead of time.
You also need to verify proper synchronization between hardware and software blocks.  Synchronization can be highly timing-dependent.  You might never see any problems when testing blocks separately, or running non cycle-accurate simulations. Then at some point you may find problems (such as in a video codec) only after 100 or more video frames have been run through the system.  So the only way to find these bugs is to do lengthy simulations with random testing, where you have the different blocks running together and stressing each other.  There is no other way to find these kinds of problems.
Q:  So, after looking at different verification solutions, what options did you consider, and why did you ultimately decide on the Cadence/Palladium III product?
A: In the past, Silicon Hive was focused more on offering standalone processors, rather than delivering full systems with application software. In this case RTL simulation with instruction-set simulation (ISS) was quite sufficient.  However, verifying multi-core solutions require much more capability than this.
At first we tried to make our high-level simulators cycle-accurate.  There's a problem -- that requires every building block in our IP portfolio to have its own abstract model, which you have to maintain. Plus the simulation speed really drops dramatically.  Then we tried working with FPGA prototype boards.  The problem there is that our designs do not typically fit onto one FPGA.  So you must partition, or modify the design, or map smaller cores.  So you end up modifying the design and not verifying what is actually being delivered.
Then we looked at hardware-based acceleration and emulation systems.  We decided against FPGA-based emulation due to long turnaround/iteration cycles and also the limited observability.  You also have the similar problem as before, where the RTL does not fit everything into one FPGA.  So we chose Palladium ultimately because of ease of integration, short iteration/turnaround cycles, full observability, and of course speed.  To verify complex video processing systems like ours, you need lengthy simulations with high visibility, and using a system like Palladium III is the only way to find real synchronization bugs in hardware and/or software.
Q:  Could you describe the transaction-based acceleration (TBA) environment you created with Palladium III?
A: So far we used Palladium III in verifying our HiveGo VSS systems -- with video you really need the highest performance possible. Our test bench consists of a bus, connected to our hardware IP and system memory, running alongside a host.  Everything except the host is synthesized to Palladium III. The host is represented by using a SystemC model that runs on a PC. The PC uses a transaction-based interface to communicate with Palladium.  The resulting speed is several hundred times faster than RTL simulation, approaching that of full in-circuit emulation.  It works very well.
Q:  How easy or difficult was it to get the whole environment to work together?
A: Quite frankly, during our first time it took quite some efforts to get the TBA interface up and running, with great support from Cadence. But now in hindsight, because we know what to do, it seems pretty easy and straightforward.  One issue was that our designs are VHDL based, while Palladium flow works better with Verilog based flow.  So if somebody was using entirely Verilog, they might not have the problems we encountered.  Another issue was adapting the compilation flow; molding the make-files into our flow took some time.
Q:  How would you compare the performance of Palladium accelerators/emulators to FPGA-based systems?
A: Of course, FPGA-based systems are generally quite faster, but that is only part of the story.  When you are verifying a complex system, what you also need to look at is iteration cycle time, which for us is even more important.   For example, the simulation speeds we are achieving with our Palladium III system are about 100 frames of full HD video in about 30 minutes (1/500 of real-time). It takes us about 20 minutes to compile the design, so total iteration cycle time is about 1 hour.  This lets our engineers run several iterations per day.
On the other hand, with an FPGA-based system you could probably run video frames 20-25 times faster, which is great, but if you run into a bug you have two real problems. First, it's very difficult to probe different signals, so finding the cause of a bug can be very challenging. Second, the time to partition and compile the design for the FPGA generally takes much longer.  You also have the problem where partitioning or adapting the design to fit or work in the FPGA might change the functionality in non-obvious ways.  So at the end, it becomes much more difficult to uncover and fix any bugs.
The FPGA approach makes the most sense when 95% of the bugs are out.  If you have any synchronization problems, corner-cases, or overflowing buffers, then you likely won't find them using an FPGA approach.
Q: Would you recommend that other companies invest in a Palladium system...why?
A: If a company is making complex system designs including hardware and software, if they want a way to run long simulations (which is very important in video and graphics applications) to discover corner cases, then I would definitely recommend a system like Palladium, certainly over any FPGA based solutions.  The primary reason is that FPGA solutions lack controllability and observability.  If you have time in your schedule, then an FPGA solution can work, but it will have longer iteration cycles.  Palladium has an enormous advantage by enabling shorter iteration cycles.
Q:  How do you see Silicon Hive and Cadence working together in the future...what's next?
A: Silicon Hive and Cadence have been working together for a long time, and we appreciate the level of support Cadence provides.  In the near future, we are exploring how to use Palladium for power exploration and power analysis in combination with TBA.  This will allow us to perform power analysis on complete software stacks.  The reason you need TBA there is because these stacks require a lot of rapid interaction between Palladium and the host in order to function correctly.  Another interest of ours is to combine Specman constrained-random testing runs with Palladium, together with TBA.
Ran Avinun
