  3. Tech Tip: Save Steps With Automatic Witness Checks
TeamVerify
TeamVerify
ABV
Formal Analysis
formal
IEV
IFV
8 Sep 2010 • Less than one minute read
This is just a quick reminder that the "witness_check" define command has an option called "auto".  When set to "auto" Incisive Formal and Enterprise Verifier ("IFV" & "IEV") will run the trace as usual, but if the trace status is "Fail" or "Explored" it will initiate the running of the trigger.  This setting may result in a little longer runtimes, but it eliminates the need to manually turn on triggers separately after running traces.
Witness_check setting summary:
  • define witness_check off
  • define witness_check trace
  • define witness_check trigger (default)
  • define witness_check auto  <--  option described above
Example usage from the tools' command prompt:
Formalverifier> define witness_check auto
Happy verifying!
Team Verify
Follow us on Twitter: http://twitter.com/teamverify, @teamverify
