  3. TileLink: Chip-Scale Cache-Coherent Interconnect Protoc…
RashmiMathanKumar
RashmiMathanKumar
TileLink
Verification IP
risc-v
VIP
cache coherency
TileLink: Chip-Scale Cache-Coherent Interconnect Protocol
23 Mar 2021 • 1 minute read
RISC-V, an open specification of an Instruction Set Architecture (ISA), which was designed to be scalable for a wide variety of applications has been enjoying wide-spread adoption in the industry.
TileLink is a free and open standard chip-scale interconnect protocol designed for RISC-V processors and beyond (could be used with other ISAs as well). It’s a fast scalable SoC communication protocol designed to connect multiprocessors, co-processors, accelerators, DMA engines, and a slew of other devices.
Any RISC-V SoC can use TileLink protocol to implement coherent memory-mapped access to memory and other slave devices. It is a master-slave point-to-point protocol in which operations are composed of messages sent over five (5) independent channels. TileLink offers many attractive features like support for out-of-order completion, by-design deadlock-free operation, and support of cache-coherent shared memory.
TileLink protocol has three conformance levels with increasing complexities which makes it possible for the protocol to be used for simple slave devices as well as for devices that require support for coherent caches. The conformance levels are:
  • TileLink Uncached Lightweight (TL-UL) - Supports simple Get/Put operations
  • TileLink Uncached Heavyweight (TL-UH) - Supports burst access, atomic operations and hints
  • TileLink Cached (TL-C) - Supports communication with coherent caches
Serving the growing need of TileLink functional verification, Cadence introduced a new TileLink VIP in its Verification IP Catalog (VIPCAT). Cadence TileLink VIP is a comprehensive Verification IP solution with support of all three conformance levels and is compliant to the latest specification versions.
TileLink VIP has the following key features:
  • Support of all three conformance levels (TL-UL, TL-UH, and TL-C)
  • Generation of all transaction types with complete control over messages and responses
  • Support of SystemVerilog, SystemVerilog UVM, and C-language User API
  • The VIP agents are highly configurable to support any combination of protocol configurations and optional features
  • The VIP includes a set of callbacks, a comprehensive checking model and a functional coverage model
We invite you to start using TileLink VIP and enjoy its power in TileLink protocol verification.
