  3. Understanding and Verifying Unified Serial Link (USL) in…
DhyeySoni
DhyeySoni
USL Verification
USL
Cadence Verification IP
Bus TurnAround
MIPI CSI-2
Unified Serial Link
MIPI CSI-2 Verification
BTA
Understanding and Verifying Unified Serial Link (USL) in MIPI CSI-2
23 Nov 2026 • 4 minute read
A camera system needs more than a path for pixels. While an image sensor sends frames to an application processor, the processor must configure the sensor, update operating settings, and request status. The sensor, in turn, needs a way to return read data and report events.
Traditionally, these functions use separate connections: CSI-2 carries the image stream, while I2C, I3C, or SPI carries camera commands. Additional GPIO wires may also be used for camera-module control. The Unified Serial Link (USL), an optional feature in MIPI CSI-2, brings camera-control communication onto the CSI-2 connection. It is designed to reduce interface wiring and support longer-reach camera architectures. Fewer wires also mean less weight and a smaller form factor, making USL a natural fit for space-constrained devices such as AR and VR glasses, where every gram and millimeter of cable routing counts.
USL also introduces a new verification challenge: image traffic and control transactions share the link, so the sensor and processor must coordinate when each side can transmit.
Figure 1. USL_FWD carries image data and responses from SNS to APP; USL_REV carries APP register requests toward SNS, with BTA coordinating link ownership.
Introduction to USL
USL uses the existing CSI-2 long packet format to carry control commands. These packets use data type 0x38, so USL builds on the CSI-2 packet structure rather than defining a separate physical connection for camera commands.
The specification describes USL as a way to reduce the need for additional I2C, I3C, or SPI interconnects for the camera command Interface, and GPIO wires for camera-module control signaling. It uses the bus-turnaround capabilities of applicable C-PHY and D-PHY transport-layer options to enable communication in both directions over the camera link.
This is useful because camera systems have naturally occurring idle periods. Horizontal blanking separates image rows, and vertical blanking separates frames. These intervals can provide opportunities to update image-sensor shadow registers while keeping control communication on the CSI-2 connection.
Meet APP and SNS
USL describes the two endpoints as APP and SNS. The SNS is the image sensor, or an image-sensor module that may include complementary non-imaging devices. It sends image data toward the processor, receives control requests, and returns responses. The APP is the application processor or host. It may include image-processing units or computer-vision engines. It receives the image stream and can send requests to configure or query the sensor.
In a conventional camera architecture, the image stream and camera commands use separate interfaces. With USL, those interactions can share the CSI-2 link.
One Link, Two Directions
USL defines two communication directions:
  • USL_FWD: The SNS transmits toward the APP.
  • USL_REV: The APP transmits toward the SNS.
The link is bidirectional, but the endpoints do not transmit simultaneously over the shared lane. A Bus Turnaround (BTA) procedure coordinates the change in ownership. In a multi-lane connection, lane 1 is bidirectional. The remaining lanes are configured for forward transmission from the image sensor. All lanes in the link can be used for USL_FWD operations, while USL_REV operations use lane 1.
The APP can use the reverse direction to send register-read and register-write requests. The SNS can return read completions, acknowledge or reject requests, and send in-band interrupt information in the forward direction. These operations let camera-control traffic share the CSI-2 transport with image data.
Key Verification Challenges
  • Link ownership and turnaround: Verify that APP and SNS follow the required handoff sequence and that the link does not stall or transmit in conflicting directions.
  • Image and control scheduling: Exercise control exchanges around frame and line boundaries, and check that image packets and control responses appear in the intended order.
  • Read and write behavior: Verify addressing, requested byte counts, returned data, and the device-specific rules for register access.
  • Response and notification handling: Check acknowledgments, rejections, read completions, and interrupts in the appropriate protocol states.
  • PHY and lane operation: Verify applicable LPDT and high-speed behavior, including the lane 1 requirement for USL LPDT.
  • Timing and error recovery: Exercise configured switching conditions, applicable acknowledgment timeouts, and recovery from selected packet or control-sequence errors.
Figure 2. Six key USL verification challenges: link ownership and BTA turnaround, image and control scheduling, read and write behavior, response and notification handling, PHY and lane operation, and timing and error recovery.
Simplifying USL Verification with Cadence CSI-2 VIP
Figure 3. Cadence CSI-2 VIP testbench for USL: Active and Passive primary/secondary agents generate and check USL transactions against a PHY-agnostic DUT across D-PHY and C-PHY.
Cadence CSI-2 Verification IP provides active stimulus and passive monitoring to help teams build and observe USL exchanges around a device under test (DUT). Transaction-level controls expose USL commands, addresses, data, and transmission options, allowing verification engineers to construct scenarios that reflect their camera architecture.
Reference scenarios cover basic USL exchanges, interleaved read completions, LPDT spacer behavior, counter-triggered turnaround, and applicable ALP acknowledgment-timeout conditions. Protocol diagnostics and functional coverage help teams investigate failures and measure which scenarios have been exercised.
These capabilities work alongside a device-aware scoreboard or register model that captures the sensor’s specific addressing and access behavior. Together, they help teams verify the interaction between image transport, camera-control requests, sensor responses, and link ownership.
USL brings camera data and control closer together on the CSI-2 connection. Verifying that integration requires a coordinated view of the sensor, processor, and shared transport, helping teams identify issues that isolated packet tests can miss.
Learn more about Cadence MIPI CSI-2 Verification IP, including key features, capabilities, and benefits, by visiting our product page: Simulation VIP for MIPI CSI-2 | Cadence. For more details, connect directly with Cadence Verification IP experts at talk_to_vip_expert@cadence.com.
