  3. Unveiling NOP Insertion Hint: A Performance Optimizer in…
Jasmine Makhija
Jasmine Makhija
256BLOptMode
CXL3.0
Latency Optimization
NOP Insertion Hint
latency
Unveiling NOP Insertion Hint: A Performance Optimizer in CXL 3.0
27 Jun 2024 • 3 minute read
Compute Express Link (CXL) is a high-speed interconnect standard that facilitates efficient, low-latency communication between processors, memories and accelerator devices such as GPUs. CXL surpasses the capabilities of traditional PCIe interfaces by offering greater flexibility and higher bandwidth making it ideal for supporting the complex demands of computing workloads.
In the fast-paced world of networking technology, optimizing performance while minimizing latency is crucial. For seamless data transmission, achieving low latency is paramount for ensuring data being transmitted effectively. One key strategy to boost performance is by using NOP(No Operation) Insertion Hints. Let’s dive into how this technique can significantly optimize performance in the context of latency-optimized 256B Flit Mode.
What does Latency-Optimized 256B Flit Mode Offer?
The latest CXL 3.0 update introduces a significant enhancement: the 256B flit mode, which is standard and latency optimized. In the latency-optimized mode, more bytes are
allocated to the physical layer to enable less store-and-forward when the transmission is error free. The 12 Bytes CRC splits across 2 6 Bytes CRC codes that allows consuming 128 bytes with good CRC with much lower latency.
Low latency is crucial in applications where real-time processing and responsiveness are essential.
This advanced feature allows the physical layer to utilize a lower latency route, effectively bypassing the Forward Error Correction (FEC) algorithms. Essentially, FEC logic enables the receiver to detect and correct errors in the received data avoiding retransmission of data from the sender.
However, in the event of a CRC error detection, the physical layer must revert to a higher latency path that incorporates FEC algorithm.
Why is NOP Insertion Integral to the 256B Latency-Optimized Mode?
The 256B Latency-Optimized mode is designed to minimize latency by allowing data to bypass certain processing steps, such as Forward Error Correction (FEC). This mode targets applications where speed and responsiveness are critical, and any delay can significantly impact performance. Using NOP insertion, the system can quickly revert to the low-latency path after temporarily switching to a higher-latency path due to error correction needs.
Navigating Latency Challenges
To transition back to the low-latency route from the FEC path, the physical layer relies on identifying bubbles within the received traffic. These bubbles, generated by SKP Ordered Set(SKP OS) or No Operation (NOP) ,the primary purpose of SKP Ordered Stets is to insert idle periods or gaps into the continuous stream of data which allows for the discarding of unnecessary flits while awaiting specific sequence numbers during replay or gap periods.
Introducing and Implementing NOP Insertion Hints
In addressing the challenge of infrequent SKP OS and resulting CRC errors, NOP Insertion Hints provide a viable solution. When a CRC error is detected, the detecting device can transmit a NOP Insertion Hint to the partner device, signaling the need for NOP Insertion. Upon receipt of this hint, the physical layer can schedule the insertion of one or two NOPs.
These NOPs facilitate a seamless transition back to the low-latency path. Hence, optimizing overall performance and ensuring efficient data transmission.
Verification in NOP Insertion for Robust Performance
Implementing NOP Insertion Hints introduces several verification challenges. Ensuring the correct detection and handling of CRC errors, and the accurate insertion of NOPs without disrupting data flow, requires rigorous testing. This involves validation of NOP Scheduling ensuring that the Physical Layer correctly schedules NOPs in response to hints either with single or back to back NOPs as per the request of link that detects CRC error.
Verifying NOP hints:
The link that detects the packet with CRC error must send the NOP Hints.
Error Handling mechanisms:
Force injecting CRC error to packets to verify that the link detects CRC error and send NOP Hints.
Validation of NOP scheduling:
Ensuring that the Physical Layer correctly schedules NOPs in response to hints.
Summary
NOP Insertion Hints present a practical solution to latency challenges encountered in network optimization. By strategically employing these hints, systems can achieve heightened performance and efficiency. This optimization drives smoother data transmission and reduced latency, ultimately boosting the user experience.
More Information:
  • For more info Cadence PCIe Verification IP and TripleCheck enables users to confidently verify disruptive changes, see our Simulation VIP for CXL, Simulation VIP for PCIe and TripleCheck for PCIe and CXL.
  • For more information on CXL in general, see CXL Consortium website.
  • If you have any queries, feel free to contact us at talk_to_vip_expert@cadence.com
