  3. Unraveling Orthogonal Header Content (OHC) in PCIe 6.0
Igor Krause
Igor Krause
VIP
PCIe
verification
11 Dec 2024 • 3 minute read
Introduction
With the arrival of Flit Mode, the information hold by the TLP header was reorganized. In addition to the base header, Orthogonal Header Content (OHC) may be added into the TLP. OHC works as an extra header for the TLP, incorporating information fields that are needed depending on the TLP type.
Background of OHC
There are multiple OHC types. Each one includes a specific set of information in the TLP packet. For specific TLP types, a specific OHC content must be included by the Transmitter.
It is permitted to include any combination of OHC content in the TLP's Header. When present, OHC must follow the Header Base in A-B-C-E order. The number of included OHC and types is indicated by the OHC field in the first DW of the TLP Header. A TLP Header may include up to 7 OHC.
The OHC[4:0] field indicates the presence of "Orthogonal Header Content" (OHC) encoded as:
  • 0 0000b = No OHC present
  • x xxx1b = OHC-A present
  • x xx1xb = OHC-B present
  • x x1xxb = OHC-C present
  • 0 0xxxb = No OHC-E present
  • 0 1xxxb = OHC-E1 present
  • 1 0xxxb = OHC-E2 present
  • 1 1xxxb = OHC-E4 present
OHC Types – When to Use
OHC-A1
OHC-A1 must be included for Requests that require any of the fields included in OHC-A1.
Memory Requests with explicit Byte Enables and/or PASID Address Routed Messages with PASID and Route to Root Complex Messages with PASID Translation Requests.
For all Memory Requests, it is permitted for OHC-A1 (see Figure 2-7) to be present. For Memory Requests, when OHC-A1 is not present, the value of the Last DW Byte Enable field must be treated as 1111b for Requests with Length greater than or equal to 2 DW, and the value of the 1st DW Byte Enable field must be treated as 1111b. If a Request requires Byte Enables field values other than these, then OHC-A1 must be present. When OHC-A1 is present, the PASID, PMR, and ER fields are valid if and only if the PV bit is set.
OHC-A2
OHC-A2 must be included for all I/O Requests.
OHC-A3
OHC-A3 must be included for all Configuration Requests.
OHC-A4
OHC-A4 must be included in ID Routed Messages when Destination Segment or PASID is required.
OHC-A
OHC-A5 is required for Unsuccessful Completions, Non-UIO Completions with Lower Address[1:0] not equal to 00b, and Completions that require the Destination Segment due to the associated Non-Posted Request containing a Requester Segment that does not match the Completer's captured Segment.
When OHC-A5 is not present, it is implied that the Completion Status is Successful, that Completer Segment and Destination Segment need not be explicitly indicated, and that, for non-UIO Completions, the Lower Address[1:0] = 00b.
OHC-B
When TLP Processing Hints (TPH) are used, OHC-B must be included with the appropriate PH and ST values.
OHC-C
IDE TLPs must include OHC-C. Non-IDE Request TLPs must, in some cases, also include OHC-C to indicate the Requester Segment.
OHC-E
The information previously present in the End-to-End Prefix is now incorporated in the TLP's header as OHC-E. OHC-E conveys content that would otherwise use E-E Prefixes 0011 to 1111.
OHC Verification Challenges and Solutions
The OHC brings new rules for the TLP header organization. The TLP header size changes according to the number of included OHC instead of relying only on the TLP type. Some features now require specific OHC, like Integrity and Data Encryption (IDE) and Process Address Space ID (PASID). End-to-end prefixes can be easily detected at the end of the header.
The solution naturally requires verification to check when OHC are included, violating the rules that allow their use. The contents inside the OHC fields need to be checked as the fields on the base TLP header. Implementers need to know all the OHC that may be included in the TLP packets and be fully aware of all the rules that define when each one must be used.
More Information
  • For more information on how Cadence PCIe Verification IP and TripleCheck VIP enable users to confidently verify PCIe 6.0, see our VIP for PCI Express, VIP for Compute Express Link, and TripleCheck for PCI Express;
  • See the PCI-Sig website for more details on PCIe in general and the different PCI standards.
