  3. USB3, PCIe, DisplayPort Protocol Traffic Finding its Way…
Neelabh
Neelabh
Verification IP
DP
DisplayPort
USB
usb4
PCIe
tunneling
USB3, PCIe, DisplayPort Protocol Traffic Finding its Way Through USB4 Routers
1 Feb 2020 • 1 minute read
USB4 can simultaneously tunnel USB3, PCIe and DisplayPort native protocol traffic through a hierarchy of USB4 routers. The key to tunneling of these protocols is routing table programmed at each ingress adapter. An entry of a routing table maps an incoming HopID, called Input/Ingress HopID to a corresponding pair of Output/Egress Adapter and Egress/Output HopID.
The responsibility of programming routing tables lies with the Connection Manager. Connection Manager, having the complete view of the hierarchy of the routers, programs the routing tables at all relevant adapter ports. Accordingly, the USB3, PCIe and DisplayPort protocol tunneled packets are routed, and reach their respective intended destinations.
The diagrammatic representation below is an example of tunneling of USB3 protocol traffic from USB4 Host Router to USB4 Peripheral Device Router through a USB4 Hub Router. The path from USB3 Host to USB3 Device is depicted by routing tables indicated at A -> B -> C -> D, and the one from USB3 Device to USB3 Host by routing tables indicated at E -> F -> G -> H . Note that the Input HopID from and Output HopID to all three protocol adapters for USB3, PCIe and DisplayPort Aux traffic, are fixed as 8, and for DisplayPort Main Link traffic are fixed as 9.
Once the native protocol traffic come into the transport layer of a USB4 router, the transport layer of it does not know to which native protocol a tunneled packet belongs to. The only way a transport layer tunneled packet is routed through the hierarchy of the routers is using the HopID values and the information programmed in the routing tables.
The figure below shows an example of tunneling of all the three USB3, PCIe and DisplayPort protocol traffic together. The transport layer tunneled packets of each of these native protocols are transported simultaneously through the routers hierarchy.
 Cadence has a mature Verification IP solution for the verification of USB3, PCIe and DisplayPort tunneling. This solution also employs the industry proven VIPs of each of these native protocols for native USB3, PCIe and DisplayPort traffic.
