  3. USB4 Sideband Channel Is Not a Side Business
Neelabh
Neelabh
USB4 VIP
USB4v2
usb4
USB4 Version 2
usb4 router
26 Nov 2024 • 4 minute read
The USB4 specification has been around for several years now. Two years ago, USB4 version 2.0 was also released by the USB Promoter Group. This specification enables up to 80Gbps link speed per direction in symmetric mode and 120Gbps link speed in asymmetric mode.
Be it Gen 2, Gen 3, or Gen 4 link speeds of 20Gbps, 40Gbps, 80Gbps, or 120Gbps, the sideband channel is indispensable for the stable operation of the high-speed link. It plays a multi-faceted role.
The sideband channel is a simple two-wire low-speed link operating at 1Mbps using 10-bit start/stop encoding that does not require any synchronization of its own. It supports different transaction types, namely, Link Type (LT), Administrative Type (AT), and Re-timer Type (RT), each having their specific roles mentioned in the table below.
The sideband channel role starts from the very beginning of bringing-up of a USB4 High-Speed link through various phases of lane initialization, to link establishment, handling different aspects of link management like Sleep entry, Disconnect/Re-connect, and to supporting link recovery when the link becomes unreliable for operation.
During lane initialization phases, its functionality ranges from being a medium for router detection by way of SBTX line being made logic high by the router in phase 2, to helping each router in getting USB4 port characteristics information of its link partner in phase 3, to broadcasting the negotiated USB4 port parameters and starting High-Speed Tx and Rx traffic in phase 4, and to negotiating transmitter Feed-Forward Equalization (TxFFE) parameters between each router or re-timer and a router or re-timer adjacent to it in phase 5.
In phase 3, the USB4 port characteristics that are exchanged determine the nature of the USB4 link. These characteristics indicate bonding support, lane speed (Gen 4, Gen 3, or Gen 2), RS-FEC enabled, and asymmetric link support (3Tx, 3Rx, or only symmetric link support).
During phase 4, a USB4 port sets the lane speed and starts transmission. Routers send broadcast RT transactions to each other bearing the negotiated link characteristics. Once these transactions are complete, routers activate the transmitter on each enabled lane at the selected speed and send SLOS1 on the high-speed link. For a Gen 3 or Gen 2 link, a router indicates this start of transmission to the link partner by sending an LT_Resume transaction and setting Tx active bit in the TxFFE register of sideband register space. For a Gen 4 link, a router transmits LFPS after setting the start TxFFE bit in the SB register space of the link partner to indicate that TxFFE negotiation process can start. After LFPS is stopped, back-to-back Gen4 TS1 with the indication field set to 1h are transmitted.
At the end of phase 4, the transmitters and receivers are ready to go to phase 5, where transmitter Feed-Forward Equalization (TxFFE) parameters between each link partner are negotiated. On completion of phase 5, the high-speed link is ready to send and receive traffic and proceed with high-speed link training.
While all sideband transaction types support the lane initialization processes in various phases, link type transactions have an important role to play once the USB4 high-speed link becomes active.
LT transactions are also used to signal a change in the lane adapter state due to events such as a lane disconnect or lane disable. They are also used for communicating sleep events from a USB4 port in a router to a USB4 port on the other router.
The Gen 4 link transitions from symmetric to asymmetric and vice-versa between two routers get requested and acknowledged using LT_SwitchRx2Tx and LT_SwitchAck link type transactions, respectively.
The Gen 4 link recovery uses ELT_Recovery extended link type transaction to initiate and complete the link recovery.
The sideband channel for a TBT3-Compatible USB4 port should also honor the variations that it has for TBT3-compatibility. This includes support for the bidirectional sideband channel.
From a functionality perspective, the sideband channel may look simple. However, it has a very wide scope and a broad impact on USB4 functioning. It is, in essence, a system that contributes significantly to the smooth running of High-Speed USB4 Link.
Hence, verifying high-speed USB4 functionalities in combination with the sideband channel cannot be overlooked. It is an important verification planning advice that qualifying a USB4 design with the sideband channel functionality should never be underestimated.
To save on simulation run time for high-speed link verification, an approach that is usually taken is to bypass the sideband channel processes if the design under verification supports it and focus only on high-speed link protocol traffic. However, it does not in any way reduce the importance of verifying the high-speed link with the sideband channel processes enabled before the closure of the verification cycle, as the sideband channel is responsible for establishing, maintaining, and providing a recovery mechanism in a USB4 port.
Cadence has a mature Verification IP solution for the verification of various aspects of USB4 version 2.0 and version 1.0 design, with verification capabilities provided to do a comprehensive verification of these.
You may refer to https://www.cadence.com/en_US/home/tools/system-design-and-verification/verification-ip/simulation-vip.html for more information.
