  3. Versatile Use Case for DDR5 DIMM Discrete Component Memory…
DurlovKhan
DurlovKhan
ddr5
DDR5 DIMM
VIP
MRDIMM
Memory Model
Versatile Use Case for DDR5 DIMM Discrete Component Memory Models
29 Oct 2024 • 6 minute read
DDR5 DIMM Architectures
The DDR5 generation of Double Data Rate DRAM memories has experienced rapid adoption in recent years. In particular, the JEDEC-defined DDR5 Dual Inline Memory Module (DIMM) cards have become a mainstay for systems looking for high-density, high-bandwidth, off-chip random access memory[1]. Within a short time, the DIMM architecture evolved from an interconnected hierarchy of only SDRAM memory devices (UDIMM[2]) to complex subsystems of interconnected components (RDIMM/LRDIMM/MRDIMM[3]).
Diagram of a typical DDR5 DIMM today
DIMM Designs and Popular Verification Use Cases
The growing complexity of the DIMMs presented a challenge for pre-silicon verification engineers who could no longer simply validate against single DDR5 SDRAM memory models. They needed to consider how their designs would perform against DIMMs connected to each channel and operating at gigahertz clock speeds.
To address this verification gap, Cadence developed DDR5 DIMM Memory Models that encapsulated all of the architectural complexities presented by real-world DIMMs based on a robust, easy-to-use, easy-to-debug, and easy-to-reconfigure methodology.
This memory-subsystem-in-a-single-instance model has seen explosive adoption among the traditional IP Developer and SOC Integrator customers of Cadence Memory Models. The Cadence DIMM models act as a single unit with all of the relevant DIMM components instantiated and interconnected within, and with all AC/Timing parameters among the various components fully matched out-of-the-box, based on JEDEC specifications as well as datasheets of actual devices in the market. The typical use-case for the DIMM models has been where the DUT is a DDR5 Memory Controller + PHY IP stack, and the validation plan mandated compliance with the JEDEC standards and Memory Device vendor datasheets.
Diagram of a typical MC+DFI DUT Testbench utilizing the DIMM Memory Model
Unique Use Case for the DIMM Discrete Component Models
Although the Cadence DIMM models have enjoyed tremendous proliferation because of their cohesive implementation and unified user API, the actual DIMM Models are built on top of powerful, flexible discrete component models, each of which was designed to stand on its own as a complete SystemVerilog UVM-based VIP. All of these discrete component models exist in the Cadence VIP Catalog as standalone VIPs, complete with their own protocol compliance checking capabilities and their own configuration mappings comprehensively modeling individual AC/Timing parameters.
Because of this deliberate design decision, the Cadence DIMM Discrete Component Models can support a unique use-case scenario. Some users seek to develop IC Designs for the various DIMM components. Such users need verification environments that can model the individual components of a DIMM and allow them the option to replace one or another component with their Component Design IP. They can then validate that their component design is fully compatible with the rest of the components on the DIMM and meets the integrity of the overall DIMM compliance with JEDEC standards or Memory Vendor datasheets.
The Cadence Memory VIP portfolio today includes various examples that demonstrate how customers can create DIMM “wrappers” by selecting from among the available DIMM discrete component models and “stitching” them together to build their own custom testbench around their specific Component Design IP.
Use-case where DUT is a DIMM Component, testbench made up of DIMM Discrete Component models
A Solution for Unique Component Scenarios
The Cadence DDR5 DIMM Memory Models and DIMM Discrete Component Models can provide users with a flexible approach to validating their specific component designs with a fully populated pre-silicon environment.
Augmented Verification Capabilities
When the DIMM “wrapper” model is augmented with the Cadence DFI VIP[4] that can simulate an MC+PHY stack and offers a SystemVerilog UVM test API to the verification engineer, the overall testbench transforms into a formidable pre-silicon validation vehicle. The DFI VIP is designed as a combination of an independent DFI MC VIP and a DFI PHY VIP connected to each other via the DFI Standard Interface and capable of operating seamlessly as a single unit. It presents a UVM Sequence API to the user into the DFI MC VIP with the Memory Interface of the PHY VIP connected to the DIMM “wrapper” model.
With this testbench in hand, the user can then fully take advantage of the UVM Sequence Library that comes with the DFI VIP to enable deep validation of their Component Design inside the DIMM “wrapper” model.
DIMM Component DUT testbench augmented with a DFI VIP
Verification Capabilities Further Enhanced
A possible further enhancement comes with the potential addition of an instance of the Cadence DIMM Memory Model in a Passive Monitor mode at the DRAM Memory Interface. The DIMM Passive Monitor consumes the same configuration describing the DIMM “wrapper” in the testbench, and thus can act as a reference model for the DIMM wrapper. If the DIMM Passive Monitor responds successfully to accesses from the DFI VIP, but the DIMM wrapper does not, then it exposes potential bugs in the DUT Components or in the settings of their AC/Timing parameters inside the DIMM wrapper.
DIMM Component DUT testbench with DFI VIP and a DIMM Passive Monitor Memory Model
Debuggability, Interface Visibility, and Protocol Compliance
One of the key benefits of the DIMM Discrete Component Models that become manifest, whether in terms of the unique use-case scenario described here, or when working with the wholly unified DDR5 DIMM Memory Models, is the increased debuggability of the protocol functionality. The intentional separation of the discrete components of a DIMM allows the user to have full visibility of the memory traffic at every datapath landmark within a DIMM structure. For example, in modeling an LRDIMM or MRDIMM, the interface between the RCD component and the SDRAM components, the interface between the RCD component and the DB components, and the interface between the SDRAM components and the DB components—all are visible and accessible to the user. The user has full access to dump the values and states of the wire interconnects at these interfaces to the waveform viewer and thus can observe and correlate the activity against any protocol violations flagged in the trace logs by any one or more of the DIMM Discrete Component Models.
Access to these interfaces is freely available when using the DIMM Discrete Component Models. On the unified DDR5 DIMM Memory Models, a feature called Debug Ports enables the same level of visibility into the individual interconnects amidst the SDRAM components, RCD components, and DB components. When combined with the Waveform Debugger[5] capability that comes built-in with the VIPs and Memory Models offered by Cadence and used with the Cadence Verisium Debug[6] tool, the enhanced debuggability becomes a powerful platform.
With these debug accesses enabled, the user can pull out transaction streams, chip state and bank state streams, mode register streams, and error message streams all right next to their RTL signals in the same Verisium Debug waveform viewer window to debug failures all in one place. The Verisium Debug tool also parses all of the log files to probe and extract messages into a fully integrated Smart Log in a tabbed window fully hyperlinked to the waveform viewer, all at your fingertips.
A Solution for Every Scenario
Cadence's DDR5 DIMM Memory Models and DIMM Discrete Component Models, partnered with the Cadence DFI VIP, can provide users with a robust and flexible approach to validating their designs thoroughly and effectively in pre-silicon verification environments ahead of tapeout commitments. The solution offers unparalleled latitude in debuggability when the Debug Ports and Waveform Debugger functions of the Memory Models are switched on and boosted with the use of the Cadence Verisium Debug tool.
[1] Shyam Sharma, DDR5 DIMM Design and Verification Considerations, 13 Jan 2023.
[2] Shyam Sharma, DDR5 UDIMM Evolution to Clock Buffered DIMMs (CUDIMM), 23 Sep 2024.
[3] Kos Gitchev, DDR5 12.8Gbps MRDIMM IP: Powering the Future of AI, HPC, and Data Centers, 26 Aug 2024.
[4] Chetan Shingala and Salehabibi Shaikh, How to Verify JEDEC DRAM Memory Controller, PHY, or Memory Device?, 29 Mar 2022.
[5] Rahul Jha, Cadence Memory Models - The Gold Standard, 15 Apr 2024.
[6] Manisha Pradhan, Accelerate Design Debugging Using Verisium Debug, 11 Jul 2023.
