  3. Virtual Platform UART Use Number 2: Using telnet to Connect…
jasona
jasona
Virtual System Platform
TLM
virtual platform
UART
telnet
embedded software
xterm
virtual prototype
software
SystemC
linux
ESL
Virtual Platform UART Use Number 2: Using telnet to Connect to a UART
6 Sep 2011 • 4 minute read
Welcome to the next installment in my series about different ways to use the venerable UART in Virtual Platforms. If you missed the first two parts you can review the introduction and use case 1, about using xterm in slave mode for an interactive terminal.
This article explains another way to provide an interactive terminal. Instead of using the xterm in slave mode we can use a network connection and the telnet program to connect to a UART and have an interactive terminal.
Recall that the UART has a simple byte interface to send characters into it and receive characters from it. As long we do this, any implementation is possible to interact with it.
To use telnet as a way to connect to the UART we replace the xterm we had before with the telnet program as shown below.
As with the xterm, the telnet program is a separate executable running in its own process. With the xterm we implemented inter-process communication (IPC) using a series of system calls to send and receive data to and from the xterm. This time we again provide inter-process communication, but using a networking socket. The implementation requires a new SystemC model which replaces the terminal model. Let's see how we can use telnet to add a connection to a SystemC UART model.
  • Create a new SystemC model, let's call this one a "telnet terminal model" with a thread to create a network connection and act as a server listening for characters to arrive on the socket, and another thread waiting for characters to arrive from the UART and sending them out on the network socket.
  • The telnet terminal model can have an option to either launch the telnet program automatically and connect to the telnet terminal model on the same machine or allow the user to manually run telnet and connect to the telnet terminal model from any other machine on the network.
  • Use the SystemC thread that was setup to process input from the network connection to read the network socket using a read system call and forward any characters that come in to the UART's rx port.
  • Use the SystemC thread that was setup to process output from the UART to wait for characters to arrive from the UART tx port and send them out on the socket using a write system call.
As you can see the flow is very much the same as the xterm solution; only the implementation of the xterm in slave mode is replaced by a network socket.
Below is the implementation of the SystemC method that is sensitive to characters coming from the UART. It writes those charaters to the network socket.
Below is the implementation of the SystemC thread that polls the network socket for new characters and upon receiving a character sends it on to the UART.
There is one additional detail in the code. The readThread() method doesn't set up the socket communication until the first write to the UART occurs in the simulation. The idea is that if there are no writes to the UART, then the interface may not be used at all during simulation, so there is no need to do anything. The first write to the UART will emit the startReading event and then the network socket will be setup using a common sequence of socket, bind, and listen system calls.
In a system running Linux, this first write will come from the traffic generated by the getty program that is used by init to open a port and start the login program so users can log in and start a shell. I will have more on this in the next article that talks about using the UART for remote debugging with gdb.
One of the configurable parameters of the SystemC telnet terminal model is the ability to automatically launch the telnet program. This implementation is different than the xterm from the last article in that it uses the popen system call to start an xterm which uses the -e option to start telnet.
A screenshot of the automatically launched telnet is shown below.
This model can also be configured to not launch telnet automatically, but instead wait for a manual connection from any other machine on the network. Users can just supply the machine name and port number as arguments to telnet.
A screenshot of the manual connection from another machine is shown below. In this case I connected to a Linux machine called Pepper on the Cadence network from my laptop using Windows telnet from the command prompt.
Like the xterm in slave mode, there are some tricks to getting the echo working correctly. This time you will see something called telnetOption that is a set of characters written into the socket. By experimentation I found that without this the characters are echoed when typed and the terminal doesn't work all that well. This gets into the details of the telnet protocol and how to send commands.
It's too deep for this article, but as always you can dig as deep as you like into the details of telnet. Here is a table of common telnet commands. You can see the commands 1 and 3 that are used in telnetOption.
Conclusion
The full details of the code are available in tterm.cpp and tterm.h. This code is for blogging purposes only, but does work for the applications I have outlined here. This is another good example of using Linux system programming to create Virtual Platform models. Next time I'll cover how this same telnet terminal model can be used to perform remote application debugging using gdb.
Jason Andrews
