  3. What Could Be Simpler than a Request-Acknowledge Handshake…
tomacadence
tomacadence
bugs
corner cases
formal
intent
assertions
simulation
What Could Be Simpler than a Request-Acknowledge Handshake?
31 Jan 2011 • 3 minute read
My last few blog posts have included three corner-case conditions that led to bugs, one in software, one in hardware, and one in real life. One of the reasons that corner-case conditions are missed is that some engineers don't spend enough time really thinking about their design and documenting its intended functionality. Writing specifications that are orthogonal to the specific hardware or software implementation provides deeper insight and often reveals difficult-to-verify conditions even before they are implemented.
In the hardware world, assertions are a popular and very valuable form of orthogonal specification of design intent. When used diligently, they provide the basis for thorough verification with testbench simulation, formal analysis and hardware acceleration. But, as with any form of specification, just the act of writing assertions can reveal inconsistencies, poorly-conceived design ideas and potential trouble spots for verification. I recall an instructive example from my stint leading the applications engineering team at 0-In Design Automation.
0-In's primary product space was formal analysis, but we also supported assertions in simulation. As an assertion-based verification (ABV) pioneer, our success on customer projects was tied directly to the quality of their assertions. When the customer, with help from my applications team, did a good job of specifying assertions, we could find some really tricky corner-case bugs. But in this particular case, we found a whole category of interesting bugs just by working with the customer to write assertions.
I can't identify the company, but I will say that it was a major networking/communications provider designing chips quite large for the time. The engineers believed strongly in design reuse, and regularly mixed and matched pieces from previous designs into the RTL for their new projects. They often found a lot of bugs related to the integration of these pieces because the original designers did not consider future reuse and did not document their blocks with either written specifications or assertions.
As my applications team started working with this customer, they learned about the history of problems related to design reuse. They decided to focus on helping the customer's engineers write assertions to document the interfaces of the reused blocks. The expectation was that simulation would reveal inconsistencies between the assumptions made by connected blocks and that formal analysis would reveal further bugs that didn't happen to be triggered in simulation. In fact, assertions provided value even before the first simulation was run because they revealed a lot of misunderstanding about what the interfaces were supposed to do.
The biggest issue I recall from the customer project is disagreement over how request-acknowledge (req-ack) interfaces should work. This is perhaps surprising; it's hard to imagine an interface protocol simpler than a req-ack handshake. The block on one side makes a request, the block on the other side acknowledges it, the first block drops its request when it has been satisfied (for example, read data received) and the second block drops its acknowledge. So what's not to understand? Well, consider these questions:
  1. What if the acknowledging block drops its ack before the req has dropped? That could be a bug, or it could be legal in certain cases such as completion of a write request.
  2. What if the requesting block drops its req before the ack arrives? This could be a bug, but it could instead be the case that the protocol allows a delayed ack.
  3. What if the requesting block then issues another req before seeing any ack? This could be a bug, or the interface could be pipelined such that a series of requests can be queued up.
  4. What if an ack never arrives? This could be a bug, or the requestor might have a timeout after which it cancels an unacknowledged request.
I could go on in this vein for quite a while; there are probably dozens of variations on the basic req-ack handshake. In the case of this particular customer project, we found a total of seven (!) req-ack variants being used just in the portion of the chip we were analyzing. That was a sure sign of trouble, but even worse the engineers really didn't understand the rules for the blocks they were reusing. Most of the req-ack interfaces were between two blocks with different protocol assumptions and therefore buggy. The process of trying to document these interfaces with assertions revealed many problems that were fixed immediately; the customer later found additional bugs with both simulation and formal.
This project, a fairly early one at 0-In, convinced me that ABV had intrinsic value. Writing assertions caused the designers to think about their assumptions in a much more rigorous way. Going into this project, we had no idea that something as "simple" as a req-ack handshake had corner cases. So when I say "verify, verify and verify some more" be sure to consider assertion specification as an essential part of the process and not just a precursor to simulation and formal.
Tom A.
The truth is out there...sometimes it's in a blog.
