  2. SoC and IP
  3. DDR3 power savings may be more important for Embedded Apps…
archive
archive
DDR3 power savings may be more important for Embedded Apps than for PCs
19 Jul 2010 • 2 minute read
A new hands-on article written by Patrick Schmid and Achim Roos just appeared on the Tom’s Hardware site (“How Much Power Does Low-Voltage DDR3 Memory Really Save?”). The article takes an in-depth, real-world look at 1.35/1.25V DDR3 SDRAM power consumption versus DDR2 SDRAM power consumption in a PC environment. Here’s the meat of the conclusion:
“There are more interesting differences in power consumption, though, which brings up back to the [Kingston HyperX DDR3 SDRAM] LoVo series. Idle power decreases only by 0.5 W when going from 1.5 V to 1.35 V and by another 0.5 W when switching to 1.25 V. This isn't much, but considering that the rest of the system remains unchanged, it's something. Peak power decreases from 178 W and 180 W at 1.5 V (DDR3-1333 and -1600 speeds) to 174 W and 177 W at 1.25 V and 1.35 V. While these numbers are certainly not very relevant to desktop PCs, the measured power consumption differences can become important once you start to power-optimize all other system components. At the end of the day, a few watts difference on a low-power desktop PC like our 25 W Core i5 system becomes quite relevant.”
What Schmid and Roos observed is that the use of low-voltage DDR3 SDRAM cut system power by about a Watt at idle and by as much as three to six Watts at peak operating loads. When the overall system dissipates well more than 100 Watts, as do most high-end multicore PCs, the relative power saving from low-voltage DDR3 SDRAM isn’t much. However, designers of mobile and wireless embedded systems that employ low-power processors try to squeeze every milliwatt out of the system design to prolong battery life and talk time, so a few Watts of power savings is a very big deal indeed.
Note: Memcon 2010 is a little more than two weeks away and we’ve already blogged about the terrific keynotes, presentations, and panels that will take place. More recently, we discussed the immense networking opportunity that’s also part of the event. A huge number of attendees from memory vendors, system vendors, and research firms are attending this year and July 28 at MemCon 2010 may be the only chance you’ll get all year to meet and speak with them as fellow attendees.
This event is open free to qualified individuals.
Once it’s over, you’ve lost your chance for another year.
Registration is nearing 600 and the room is getting pretty crowded, so please hurry to make sure you get in before the doors close. For free registration and admission to MemCon 2010, click here.
