  2. SoC and IP
  3. Driving Innovation: Cadence's Cutting-Edge IP on TSMC's…
Frank Ferro
Frank Ferro
ucie
Memory
LPDDR
ip cores
PCIe
DDR
GDDR7
Driving Innovation: Cadence's Cutting-Edge IP on TSMC's N3 Node
14 Oct 2024 • 2 minute read
Staying ahead of the curve is essential to meeting customer needs. Cadence has consistently demonstrated its commitment to innovation, and its latest IP portfolio available on TSMC's 3nm (N3) process is no exception. Today, rapid advancements in AI/ML, hyperscale computing (HPC), and the automotive industry are driving significant changes in technology. Let's explore the impressive array of IP that Cadence offers on this advanced node.
Memory Solutions: High-Speed and Power-Efficient
Cadence's DDR5 12.8G MRDIMM IP supports the highest speed grade Gen2 MRDIMMs and features a fully hardened PHY optimized to the customer's floorplan. The LPDDR5X IP is silicon-proven at 9.6Gbps and is ideal for power-sensitive applications, offering a fully integrated memory subsystem.
GDDR7: Leading the Way in Graphics Memory
Cadence has achieved a significant milestone with the world's first silicon-proven GDDR7 IP, supporting data rates up to 32Gbps. This IP offers the best price/performance ratio for AI interfaces, making it a game-changer in the graphics memory domain.
PCIe and CXL Solutions: Robust and Reliable
Cadence's PCIe 3.0 IP is a mature and production-proven solution available across a wide range of process nodes from 28nm to 3nm. It offers a versatile multi-link architecture for optimum SoC configurability and flexible use cases. The PCIe 6.0 and CXL 3.x solutions are silicon-proven, power-optimized, and highly robust, with jitter-tolerant capabilities. These IP are the only subsystem proven with eight lanes of controller and PHY in silicon, ensuring interoperability with leading test vendors and OEMs.
UCIe PHY: Setting New Standards
The UCIe PHY IP from Cadence are set to be generally available after successful silicon characterization in both standard and advanced package options on the TSMC N3 (3nm) process. These IP demonstrate significantly better power, performance, and area (PPA) metrics than the specifications, with a bit error rate (BER) better than 1E-27 compared to the spec of 1E-15. The power consumption is also notably lower than the spec limit, ensuring a simpler integration with a best-in-class power profile.
112G PHY IP: Pushing the Boundaries of Performance
Cadence's 112G PHY IP are designed to meet the demands of high-speed data transmission. The 112G-ULR PHY IP, characterized in the 3nm process, showcases exceptional performance with support for insertion loss over 45dB at data rates ranging from 1.25Gbps to 112.5Gbps. This IP is optimized for both power and area, making it a versatile choice for various applications. The 112G-VSR/MR PHY IP also stands out with its excellent power and performance metrics, making it ideal for short-reach applications and optical interconnects. Additionally, the 112G PAM4 PHY solutions cater to hyperscale, AI, HPC, and optics applications, featuring a mature DSP-based SerDes architecture with advanced techniques such as reflection cancellation.
Cadence's IP portfolio on TSMC N3 shows innovation and expertise to solve today's design challenges. From high-speed PHY IP to robust PCIe and CXL solutions and advanced memory IP, Cadence continues to lead the way in semiconductor IP development. These solutions not only meet but exceed industry standards, ensuring that customers can confidently achieve their design goals. Stay tuned for more updates on Cadence's groundbreaking advancements in semiconductor technology.
Learn more about Cadence IP and other silicon solutions.
