  2. SoC and IP
  3. Ethernet Reaches into Ever More Application Spaces
ArthurM
ArthurM
HDD
802.3bs
Automotive Ethernet
Ethernet
Design IP and Verification IP
Ethernet PHYs
1 Oct 2015 • 2 minute read
I blog from time to time about what’s new in Ethernet. I have just returned from the latest 802.3 meeting in Florida. IEEE 802.3 is the forum that maintains and updates Ethernet standards.
 Here are some photos from Florida, I particularly like the one of the manatee I saw near the meeting hotel during a lunchtime walk:
There seems to be more activity going on in 802.3 than ever before with Ethernet spreading into ever more application spaces. The latest field is disk drives with a new study group getting underway to promote an Ethernet standard for hard disk drives.
You might think that hard disk drives (HDDs) are about to be replaced by flash memory. This is true for laptops and PCs but it is not true for the data warehouses that need to store ever more data. No doubt everyone is aware that hundreds of millions of photos are uploaded to Facebook everyday, but it is not just social media companies that require huge amounts of data storage.
For example, I was told that a jet engine may generate a terabyte of data on each flight and this is stored for the life of the engine in case it may be needed for analysis sometime in the future. Enormous amounts of data is being stored because it might at some time have value for data mining, and this needs to be done in the most cost effective manner.
What is the relevance of Ethernet to HDDs? The vision is that if a low-cost 5Gbps serial PHY can be developed that runs over SATA channels, Ethernet can be used to connect to HDDs. Using Ethernet has the advantage that you can then embed a low-cost CPU in the disk drive and then implement novel file systems in firmware. This allows sophisticated data storage techniques where data can be split over multiple HDDs for rapid retrieval or replicated over many different locations for redundancy.
In addition to the HDD work, there is good progress being made on the automotive Ethernet standards:
  • The 802.3bw project is now complete, which has created an open 802.3 standard for 100Mbps Ethernet over single twisted pair wiring for an automotive environment.
  • The 802.3bp standard for 1Gbps Ethernet over similar wiring is moving towards completion with the final stage of balloting (sponsor ballot) due to start in November.
  • The 802.3bv project, which is working to produce a 1Gbps PHY for plastic optical fibre (POF) is making less good progress. The 802.3bv PHY is intended to work with very cheap and poor quality LEDs and POF but this adds much complexity to the PHY and has led to difficulties in writing the POF standard.
  • The 802.3bs 400Gbps project is now making progress and has published its first draft. One of the most significant things in this standard is the 50Gbps-per-lane electrical interface, which is based on PAM4 modulation with Reed Solomon FEC.
  • There is now much interest in developing 50G Ethernet PHYs based on this technology. There is likely to be a “Call for Interest” (CFI) at the next 802.3 meeting in November to start work on a 50G standard. This project is likely to also include a 200Gbps PHY.
Arthur Marris
