  2. SoC and IP
  3. IEEE Spectrum article provides more insight into HP/Hynix…
archive
archive
IEEE Spectrum article provides more insight into HP/Hynix memristor pact
13 Sep 2010 • Less than one minute read
Despite some obvious technical flaws (DRAM cost/bit is not 10x less than NAND Flash! The article means to invoke the cost of hard-disk storage, not DRAM.), this article in IEEE Spectrum provides some additional insights into the recent pact between HP and Hynix to commercialize HP Labs’ memristor developments. Key takeaways:
  • “Hynix says it is looking to HP’s architecture to form the basis of its next-generation memory strategy.”
  • Hynix seeks to eventually replace both flash and DRAM with the new [memristor] device.
  • The goal is to produce devices with 2x the bit density of NAND Flash by 2013.
