  2. SoC and IP
  3. SD Association adds pins to SD card format to boost transfer…
archive
archive
SD Association adds pins to SD card format to boost transfer rates to 300 Mbytes/sec
7 Sep 2010 • Less than one minute read
Hot on the heels of the rollout of high-speed SDHC and SDXC UHS-I cards that approach 100 Mbytes/sec (see previous blog entry), the SD Association has unveiled plans to add more pins to the physical SD package to boost read/write transfer rates into the hundreds of Mbytes/sec. The UHS-I spec currently has a maximum transfer rate of 104 Mbytes/sec. The new 4.0 SD specification, due out early next year, adds a second row of pins behind the first row to boost bandwidth to as much as 300 Mbytes/sec through I/O parallelism. Cards with the second row of pins will be backwards compatible with the existing single-row cards. (Press release here.)
