  2. SoC and IP
  3. The Peripheral Challenge of Physical AI
Joe C
Joe C
USB 3.0
gpio
Design IP
peripherals
MIPI Alliance
UART
MIPI
DisplayPort
USB
spi
eUSB
embedded displayport
Soundwire
I3C
24 Nov 2026 • 7 minute read
Most physical AI discussions begin with models and accelerators. Yet a robot, vehicle, drone, or industrial machine can only reason about the physical world through the signals its peripherals capture, and it can only act through the control and output paths connected to those peripherals.
That places peripheral architecture directly in the sensing-to-action loop. Cameras, microphones, inertial sensors, encoders, displays, motor controllers, and safety devices produce and consume data with different rates, formats, and timing requirements. The challenge is not simply to connect more devices. It is to preserve the meaning and timing of physical information as it moves into the system, through preprocessing and inference, and back out as action.
The design must preserve sensor context, fit within power, area, pin, and thermal limits, and remain predictable while high-bandwidth streams, control traffic, audio, display updates, interrupts, and actuation feedback operate together.
Figure 1. Peripherals connect sensing, compute, and actuation in physical AI.
The AI Pipeline Starts at the Peripheral
Consider a humanoid robot operating in a warehouse or factory. Cameras and depth sensors provide visual context. Microphones capture speech and environmental sounds. Inertial sensors track orientation, while joint encoders and force sensors report position and load. These inputs arrive with different rates and formats, so the system must buffer, align, condition, timestamp, and route them before inference begins.
Vision usually creates the heaviest ingress workload. A humanoid, autonomous vehicle, drone, or inspection robot may use several cameras with different resolutions, frame rates, and fields of view. MIPI CSI-2 carries image data from the sensors, but buffering, image processing, timestamping, and sensor fusion must preserve both the data and its timing context before it reaches an NPU. A link can meet its nominal line rate and still fail the application if frames are misaligned or downstream processing adds too much delay.
The input side is therefore an active part of the AI pipeline. Compute performance cannot compensate for sensor data that has already lost its signal quality or timing context.
Together, these stages form one continuous sensing-to-action pipeline, as shown in figure 2.
Figure 2. The peripheral pipeline converts physical signals into inference-ready data and returns decisions as action.
Control Traffic Carries More Weight Than Its Size Suggests
Many peripherals exchange only short measurements, configuration values, status information, or interrupts. I3C, I2C, SPI, UART, GPIO, and PWM support these lower-rate control functions. Their bandwidth requirements may be modest, but their timing can directly affect system behavior.
The control path must remain coordinated with the data path. A camera can deliver every pixel correctly while using an outdated exposure setting, or an inertial sensor can have a fresh measurement waiting while its interrupt remains unserviced. Architects therefore need to consider interrupt response, bus contention, device-state changes, fault handling, and recovery rather than judging these interfaces only by data rate.
Different Peripherals, Different Timing Needs
Audio uses less bandwidth than vision, but it places strict demands on continuity and synchronization. A humanoid or service robot may use several microphones for voice interaction, sound localization, and environmental awareness. SoundWire and SWI3S provide embedded audio paths for microphones, amplifiers, and speakers, while front-end processing prepares the streams for inference. Dropped samples or channel drift can reduce recognition and localization accuracy even when the overall data rate is modest.
Display traffic follows a different pattern. MIPI DSI-2 supports tightly integrated panels, while embedded DisplayPort (eDP) and DisplayPort (DP) address broader internal and external display requirements. The choice depends on resolution, refresh rate, reach, power, and whether the panel is integrated or externally attached. Display timing affects usability, but it should not normally receive the same priority as sensor capture or actuation feedback.
External attachment introduces another set of priorities. USB is useful for removable cameras, external storage, service tools, and diagnostic equipment where discovery, standardized device classes, and software compatibility matter. USB-C may also carry DP through Alt Mode in supported designs, although USB and DP remain separate protocols. Fixed embedded cameras, audio devices, displays, and control functions may be better served by interfaces optimized for their timing, pin-count, and power requirements.
Actuation Closes the Loop
Physical AI does not end when inference produces a result. The result must reach a motor controller, robotic joint, steering system, or another physical endpoint. The appropriate interface depends on the required control rate, physical reach, electrical environment, and safety concept.
Feedback closes the loop. Encoders, force sensors, current monitors, and safety circuits report whether the intended action occurred, and that information enters the next control cycle. Input, actuation, and feedback paths must therefore be designed as one continuous system.
Peripheral Diversity Becomes an Integration Problem
A physical AI SoC may need camera ingress, audio, sensor control, embedded and external displays, USB, debug, and actuator-control connections within a limited die area and I/O pad budget. Integrating MIPI CSI-2, I3C, SoundWire, DSI, DP, USB, and lower-speed control interfaces is therefore a first-order architectural decision, not a detail to settle after the compute architecture is fixed.
These interfaces span different voltage, clock, power, physical-layer, and software domains. They do not share one interchangeable SerDes PHY. I3C and SPI are lower-speed control buses, SoundWire has its own electrical model, and CSI-2 and DSI-2 use MIPI PHY options. USB and DP may share a compatible high-speed multi-protocol PHY in supported configurations, but they remain separate protocols with their own controller and integration requirements.
The SoC must allocate pins, PHY resources, DMA channels, interrupts, buffers, security policy, and software ownership across the full peripheral set. The correct interface therefore depends on the peripheral’s function and the behavior of its data, not simply on which standards the SoC can support.
Peripheral role
Interface families
Primary design pressure
High-bandwidth sensing
MIPI CSI-2 over C-PHY, D-PHY, or A-PHY
Throughput, synchronization, buffering, and reach
Sensor control and status
I3C, I2C, SPI, GPIO
Interrupt response, contention, and software ownership
Embedded audio
SoundWire, SWI3S
Continuity, channel alignment, EMI, and low power
Embedded and external display
MIPI DSI/DSI-2, eDP, DP
Resolution, refresh rate, link power, reach, and software ecosystem
Actuation and feedback
PWM, SPI, CAN, industrial networks
Control rate, feedback timing, and fault response
External attachment
USB; USB with DP Alt Mode where supported
Compatibility, discovery, software ecosystem, and lifecycle
Integration also changes verification. Each interface may pass its own compliance tests while the complete device still fails under realistic operation. A camera mode change can increase DMA traffic, an audio event can trigger a new inference workload, and a USB or display transfer can compete for memory while several vision streams are active.
Verification must therefore extend beyond protocol compliance. Startup sequencing, simultaneous traffic, low-power transitions, device-mode changes, faults, and recovery should be tested as part of the complete sensing-to-action path. The objective is to confirm that the peripheral subsystem remains stable when the interfaces interact, not only when each interface is tested in isolation.
Four Questions to Set the Architecture
With the peripheral roles mapped, the final step is to evaluate how the interfaces will operate together across the complete sensing-to-action loop:
  • Data-path fit: Does the interface match the data type, rate, direction, and physical reach?
  • Timing coordination: Can related sensor streams, control transactions, and feedback signals remain synchronized?
  • Data preparation: Where will buffering, signal conditioning, security checks, and format conversion occur?
  • Lifecycle behavior: How will the system handle startup, low-power transitions, device-mode changes, faults, and recovery while other peripherals remain active?
Conclusion
Memory determines where active data resides. Interconnect determines how data moves across the package and platform. Peripherals determine how the system encounters the physical world and how its decisions return as action. A physical AI device can have capable compute, sufficient memory bandwidth, and fast internal links and still perform poorly if its sensors are misaligned, its inputs are poorly conditioned, its control transactions arrive late, or its actuators do not receive timely commands.
The peripheral challenge is not simply supporting more cameras, microphones, displays, or control buses. It is preserving the meaning, timing, and integrity of physical information as signals enter the device, pass through preprocessing and inference, and return through actuation and feedback.
Learn more about how to architect physical AI systems with design IP in Cadence’s “Designing Physical AI Systems Under Real-World Constraints” white paper.
References
  1. MIPI Alliance, “MIPI Camera Serial Interface 2 (CSI-2).” Source
  2. MIPI Alliance, “MIPI I3C and I3C Basic.” Source
  3. MIPI Alliance, “MIPI SoundWire.” Source
  4. MIPI Alliance, “MIPI SWI3S.” Source
  5. MIPI Alliance, “MIPI Display Serial Interface 2 (DSI-2).” Source
  6. VESA, “DisplayPort Standard.” Source
  7. Cadence, “MIPI Controller and PHY IP.” Source
  8. Cadence, “Simulation VIP for DisplayPort.” Source
  9. Cadence, “Designing Physical AI Systems Under Real-World Constraints.” Source
