  2. Life at Cadence
  3. Cadence Expands into Computational Fluid Dynamics
Ben Gu
Ben Gu
CFD
17 Nov 2021 • 5 minute read
Cadence is a leader in intelligent system design, with the aim to simulate the impossible with both speed and accuracy. Built upon our history of solving EDA challenges, Cadence’s core competency is resolving systems with over a billion design elements.
With the acquisitions of NUMECA and Pointwise earlier this year, we established our position in the world of computational fluid dynamics, or CFD. The Omnis environment from NUMECA will serve as a platform for the complete CFD workflow: meshing, solving, and post-processing. The efficiencies from our world-class solvers are amazing, and performance will continue to be accelerated in the coming years. Customers will benefit from the improved user experience of not having to switch platforms to set up, run, and analyze a model. The CFD mesh generation technology from Pointwise will continue to lead the industry for analysts requiring full control of the mesh when addressing both high-fidelity and exotic applications.
You might ask, “Why is Cadence getting into computational fluid dynamics?” Cadence’s 30 years of EDA computational software can be applied to CFD. Cloud and GPUs are exciting areas of current development across our multiphysics system analysis portfolio—including CFD. Many of the market’s legacy MCAE solvers were written in the days when computers had only one CPU core. Cadence is developing new solvers that natively take advantage of massive cloud infrastructure ranging up to tens of thousands of CPU cores and hundreds of GPUs with near ideal scaling. The coming years will be quite exciting, and our customers will be able to realize the full benefit from years of heavy R&D effort.
These improvements propose a paradigm shift for how analysts approach solving engineering challenges. They can now decide if it is more desirable to achieve the same results in a fraction of the time, increase the accuracy of the solution, or explore 10 times as many designs. Now they can confidently explore the full design space rather than just playing it safe with a few configurations or operating conditions.
Automotive Cockpit
Figure 1: Emergence of intelligent systems
High-Performance Intelligent Machines
Not only is your car getting smarter, delivering greater safety and convenience, but your connected devices, appliances, and home are all using artificial intelligence to deliver better experiences. The same revolution is happening in industrial applications, enabling smart factories, smart machines, and smart infrastructure. This boom in intelligent systems represents a primary business opportunity for our generation, and the companies that embrace this opportunity will be in a leadership position for decades to come.
Designing high-performance systems requires optimizing the machine in all its physics, including the aero dynamics, mechanical movements, electromagnetic radiation, thermal generation, interior cooling, electronic signal transmission, data gathering, data processing, and more. And each of these dimensions is interacting with others. To optimize any one physics requires analysis in the context of others and making design adjustments while assessing the impact on each.
High Performance Machines
Figure 2: High-performance machines
Why Computational Fluid Dynamics?
CFD plays a critical role in predicting real-world product performance for the automotive, aerospace and defense, consumer products, biomedical devices, industrial machinery, and power generation industries. As R&D cycles become more compressed, the need for digital prototyping increases. Exploring the full design envelope and selecting the optimal geometry configuration early on saves time and money.
To successfully address these challenges, a new vision for design is needed. A vision that deals with the system-level forces impinging on both the mechanical and electronic subsystems. What is needed is a system design solution that can extract models without simplification, simulate and analyze complex electromechanical systems, and deliver the mandated performance without any over-design.
Virtual prototyping of those systems (creating digital twins) goes a long way in containing cost and speeding time to market. This is only possible with a system simulation solution that is architected for massively parallel operation across thousands of cores. It must deliver virtually unlimited scalability and significant performance gains while maintaining the gold standard accuracy.
EDA and CFD Convergence
Many Cadence EDA customers are also CFD users, designing electronics systems that must be simulated across chip, package, PCB, and encasement. As the physics of machines becomes more leading edge, their interaction with other physics becomes more sensitive to heat, vibration, and electromagnetics. EDA uses a technology called Finite Element Analysis (FEA), similar to CFD in its use of meshing. While FEA traditionally focuses on modeling a physical product, CFD models the fluid flows (usually air or water) around the object. For electronics, CFD can be used to characterize the airflow from a fan mounted on the enclosure, and FEA can be leveraged to accurately model the heat spread throughout the PCB.
NUMECA's reputation in meshing, turbomachinery, and marine applications is world-leading. NUMECA's technologies have been adopted by industry leaders such as NASA, Honda, and Ford, expanding Cadence’s customer base. Pointwise is a leader in mesh generation for CFD, with a core competency in robust grid generation that squarely addresses the aerospace industry’s demand for high-fidelity discretization of aircraft geometries. Pointwise technologies have been adopted by leading organizations such as Hermeus, senseFly, and ONERA.
Fast Growing Industries
Figure 3: Industries requiring accurate and high-performance physics simulation
Fast-Growing CFD Market Segment
Mechanical CFD and electrical EDA physics are increasingly interdependent and are necessary to ensure expected system behavior and performance. Over the last few years, Cadence has expanded our system analysis portfolio of internally developed computational software products such as Clarity 3D Solver, Celsius Thermal Solver, and Clarity 3D Transient Solver.
The EDA market segment is very healthy, growing at the upper single-digit CAGR%. The double-digit CAGR%, fast-growing CFD market is estimated to be $1.6B. Our system design and analysis revenue was reported at ~11% of overall revenue, and CFD-related revenues will add to that to drive the growth rate of the overall company.
Figure 4: System analysis market segment size
The Computational Software Advantage
Besides these good business reasons, CFD and EDA share an underlying computational software technology base. Engineers that are skilled at EDA algorithms are similarly skilled at algorithms used in CFD. The expertise in electronics design of hardware accelerators is directly relevant to speeding up algorithm computation. Innovations in core algorithms and strategies for EDA or CFD are beneficially applicable in the other area.
Conclusion
The future of intelligent system design is multiphysics analysis within a complex design space leveraging the most advanced computing systems. Today’s leading engineering organizations need a computational software partner who is founded on world-class technology, embraces the future, and has the vision to build the capabilities required to achieve it. Cadence is uniquely positioned to be your partner for the exciting times to come.
