  3. A Methodology for Early and Iterative Optimization of Chiplet…
MSATeam
MSATeam
Celsius Thermal Solver
Sigrity X
Power Integrity
Allegro Package Designer
Signal Integrity
Innovus
Allegro Advanced Substrate Router
Clarity 3D Solver
Virtuoso Layout Suite
allegro x
multiphysics
A Methodology for Early and Iterative Optimization of Chiplet Integration
27 Nov 2026 • 6 minute read
As semiconductor packaging technologies increase in complexity due to rapid growth in the number of signals and the integration of high-bandwidth memory (HBM), high-speed interface areas are a key focus for design and analysis. This complexity challenges traditional design and analysis workflows, as importing large designs into analysis tools and managing redesigns can exceed project time constraints, making it difficult to meet deadlines. Engineers need to be able to accelerate advanced IC package design to remain competitive and deliver products to market as quickly as possible. The figure below illustrates a common example of 3D die/wafer stacking vs. the traditional 2D system-on-chip (SoC).
This white paper presents a comprehensive methodology developed by Cadence that embeds multiphysics analysis directly into the package design environment, enabling iterative optimization from the earliest floor-planning stages through final signoff. By integrating in-design analysis (IDA) directly into the design environment and leveraging scalable multiphysics simulation engines, IC package engineers can compress design cycles, reduce late-stage surprises, and achieve confident sign-off on complex advanced package designs.
Advanced Packaging Landscape
Historically, advanced IC packaging was often considered a necessary evil to avoid negative electrical, thermal, and mechanical impacts on the die side, as well as to be able to redistribute the input/output (I/O) specifically to a pitch that would be more suitable for the PCB layout. Today’s designs are focused on multi-chip(let) solutions that create value and differentiation from the competition. Modern advanced packages are themselves system-level integration platforms, responsible for managing bandwidth, power delivery, thermal dissipation, and signal routing between heterogeneous chiplets. The figure below shows traditional (left) vs modern (right) advanced packaging.
This structural shift has been driven by the fact that the package is now a system, as well as the front-end style process control that's commonly used on the fab side is now being pushed into the IC package manufacturing assembly side. The design side has also shifted to support these structural changes.
Cadence Methodology: Integrated Design and Analysis
As packaging becomes more complex, Cadence design technology is rapidly evolving to meet key requirements, including 3D planning, silicon bridges, in-design analysis, automated substrate routing, physical verification (layout vs. schematic), and more.
Cadence’s suite of integrated tools within the Allegro X Advanced Package Designer platform targets specific needs such as techfile-driven, correct-by-construction layout, and foundry-based packaging technologies, as well as flexible connectivity creation. This includes layout-driven design, automated library development, seamless 3D EM and thermal modeling integration, in-design electrical analysis, design for assembly (DFA), design for manufacturability (DFM), and co-design capabilities for analog and digital silicon (Innovus+ Synthesis and Implementation System and Virtuoso Layout Suite).
The centerpiece of the Cadence methodology is in-design analysis—the ability to perform comprehensive multiphysics simulations directly within the design environment, without exporting to external tools or waiting for a complete design. IDA supports:
  • Signal integrity: Impedance profiling, crosstalk analysis, eye diagram evaluation
  • Power integrity: DC drop analysis, AC impedance, decoupling optimization
  • Thermal analysis: Temperature distribution, hotspot identification, thermal path optimization
  • 3D electromagnetic (EM) extraction: Full-wave analysis of critical structures
By embedding these capabilities directly into the design tool, engineers can evaluate the impact of routing and placement decisions in near real time. This eliminates the traditional design-export-simulate-reimport cycle, compressing what previously took days into hours.
Package-Level In-Design Analysis
Multiphysics analysis workflows for analyzing thermal, impedance, coupling, crosstalk, PI, SI, and more are all available directly within the Allegro X Advanced Package Designer environment using the Clarity 3D Solver, Celsius Thermal Solver, and Sigrity X SI/PI simulation engines. This provides rapid feedback that helps uncover impedance discontinuities and return-path problems, enabling the user to make corrections directly within the design canvas and recheck using the same simulation engines, without switching back and forth between design and simulation tools. In design analysis, this is a key differentiator.
Many designers can't wait until the design is complete to perform analysis, and even if they want to make changes during the design flow, the design is so large and takes so much time to translate into third-party analysis tools that the process becomes inefficient and untenable. Designers in the hyperscaler environment have already adopted the idea of selectively cutting an area of the design and creating a smaller piece within the same design tool. The Cadence workflow provides the ability to look at sections of the design, perform rapid simulations, and make design changes quickly, and, when it makes sense, to replicate those decisions.
Multi-Die Floor Planning
Early-stage floor planning has a critical impact on overall design quality. Die placement decisions made in the first hours of a project constrain signal path lengths, thermal gradients, and mechanical stress distributions for the remainder of the design cycle. Poor floor planning decisions discovered late in the design process are extremely costly to correct. Cadence's floor planning tools enable engineers to evaluate die placement alternatives and analyze their electrical and thermal implications before detailed routing begins. This front-loads design intelligence, reduces the probability of late-stage issues, and shortens the overall development timeline.
Allegro Automated ASR
Manual routing of complex multi-die packages is no longer practical. The Allegro X advanced substrate router (ASR) feature provides automated routing capabilities for die-to-die and die-to-substrate connections, including support for differential pairs, shape insertion, and hierarchical routing structures. The figure below illustrates the Allegro X ASR advanced substrate/RDL router (constraint-driven).
Constraint-Driven Design
The Allegro X platform offers advanced support for complex PCB and IC package designs, facilitating a correct-by-design methodology. The constraint manager is accessible from both the design authoring tools and the actual design tool and is also available within the IDA environment. This feature allows designers to enter or manage constraints during design authoring or layout, enabling IP design reuse and collaborative team efforts.
Advanced IC Package Signal Integrity Analysis and Signoff
Signoff verification must provide confidence that the manufactured package will meet all specifications across all operating conditions. Cadence's signoff flow supports a full range of advanced interconnect topologies—2.5D, Taiwan Semiconductor’s chip-on-wafer-on-substrate (CoWoS), and 3D-IC wafer stacking—through an integrated suite of EM extraction and time-domain analysis tools.
The workflow spans both pre-layout and post-layout stages. Pre-layout simulations using parameterized models allow early identification of architectural risks. Post-layout simulations using extracted EM models provide high-fidelity verification of the as-designed structure.
Conclusion
Advanced IC package design has reached an inflection point wherein package complexity, driven by chiplet integration, 2.5D/3D stacking, and the demands of AI and hyperscale computing, has outpaced the capacity of traditional design and analysis workflows. Meeting project schedules while achieving robust, verified designs requires a fundamental change in methodology, and Cadence’s integrated IDA approach addresses that challenge directly.
By embedding multiphysics simulation into the design environment, automating constraint management and routing, and providing scalable signoff simulation through the Clarity 3D Solver and Sigrity X platforms, Cadence enables package engineering teams to work faster, iterate more freely, and deliver higher-quality results with greater confidence.
As packaging continues to evolve—with heterogeneous integration, advanced bonding technologies, and increasing system-level complexity—the ability to analyze and continuously optimize designs throughout the development process will become not just a competitive advantage but a prerequisite for success.
The white paper offering complete detail on the Cadence integrated methodology for early and iterative optimization of chiplet integration can be found here. You might also like the webinar “Using In-Design Analysis to Cut PCB Design Cycles in Half,” which highlights how integrating IDA workflows with Cadence’s Allegro X, Sigrity X, and Clarity 3D Solver can transform your PCB design process, available on demand here.
