  3. IC Packagers: Training Insights: What's New in the Allegro…
DanGerard
DanGerard
22.1
IC Packagers
Training Insights
online training
IC Packagers: Training Insights: What's New in the Allegro X Advanced Package Designer Course
18 Nov 2022 • 3 minute read
 The Allegro X Advanced Package Designer course provides all the essential training required to start working with Allegro X Advanced Package Designer. The course covers all the design tasks, including importing IC data, BGA generation and connectivity generation, constraints setup, placement, routing, post-processing, and Gerber generation. We upgrade this course regularly to stay updated with the latest changes in the product.
Some of the newly added topics in the existing training modules that might interest you are discussed here:
Creating a BGA Component with the BGA Generator
The BGA component is the interface from an IC Package design to the next level carrier in the system, which is usually the printed circuit board.
 BGA edit
In Module 3 of the course, you learn how to use the BGA Generator to create a 421-pin BGA component and then use the Symbol Edit application mode in Allegro X Advanced Package Designer to modify the BGA.
Importing DIE Information Into Allegro X Advanced Package Designer
Die information can be imported into the Allegro X Advanced Package Designer environment in many ways including a Die Generator Text-in Wizard, or by importing GDSII data and converting it into a Die symbol.
 Import DIE info
In Module 4, first, you learn to create a flip-chip die by importing information from a text file, and then create a wire bond die by importing information from a GDSII file and converting the data into a Die symbol.
Assigning Die to BGA Pins
One of the main tasks in IC Package design is Die to BGA pinout assignments. Allegro X Advanced Package Designer has many features that quickly and automatically optimize the Die to BGA pinout assignments in a package design.
 Die to BGA
In Module 5, you will learn how to assign die pins to BGA pins using the Auto Assign Net command by specifying the shortest Manhattan distance and the minimum number of ratsnest crossings. You will also learn how to assign pins manually for the most critical or pre-defined nets.
Checking 3D Wire Bond
Wire bonds are the electrical connections from the wire bond die to the surface of the IC Package substrate. Visualizing these elements in three dimensions is critical to ensure the connection between the die and substrate.
 3D wire bond
In Module 7, you define 3D wire bond profiles and add wire bonds from your die pins to bond fingers on the surface of the IC Package substrate. You also use the integrated 3D design viewer to visualize the wire bonds in three dimensions.
 To learn in detail about this course, enroll in the course Allegro X Advanced Package Designer v22.1 (Online) on the Cadence Support portal.
Click the training byte link now or visit Cadence Support and search for this training byte under Video Library.
If you find the post useful and want to delve deeper into training details, enroll in the following online training course for lab instructions and a downloadable design:
course_logoAllegro X Advanced Package Designer Plus v22.1 (Online) You can become Cadence Certified once you complete the course.
Cadence Training Services now offers free Digital Badges for all popular online training courses. These badges indicate proficiency in a certain technology or skill and give you a way to validate your expertise to managers and potential employers. You can add the digital badge to your email signature or any social media channels, such as Facebook or LinkedIn, to highlight your expertise.
To find out more, see the blog post Take a Cadence Masterclass and Get a Badge.
You might also be interested in the training Learning Map that guides you through recommended course flows as well as tool experience and knowledge-level training modules. To find information on how to get an account on the Cadence Learning and Support portal, see here.
SUBSCRIBE to the Cadence training newsletter to be updated about upcoming training, webinars, and much more. If you have any questions about courses, schedules, online training, blended/virtual live training, or public, or onsite live training, reach out to us at Cadence Training.
