  3. Simultaneous Switching Noise Analysis – The Earlier the…
TeamAllegro
TeamAllegro
electronics design
signal integrity analysis
Signal Integrity
Sigrity
SI analysis and modeling
Simultaneous Switching Noise Analysis – The Earlier the Better
23 Jun 2013 • 2 minute read
The evolution of signal integrity analysis is similar to many electronic design tasks.  First, best practices were followed. Second, analysis tools were used to verify final designs. Then, to reduce design re-spins, what-if analysis techniques were created to drive constraints that could then be verified at the end of the design cycle.
 Because of tight schedules and time to market pressure, there is often little time to circle back at the end of the design cycle when a problem is discovered during the verification phase.  The pressure is on to make sure that analysis done early will identify all potential problems. However, as sophistication in analysis tools increases, the data used in what-if analysis must also increase in sophistication to provide meaningful results during the early design process.
 An example of how sophisticated analysis tools are becoming can be seen in memory interface analysis.  Many simultaneous switching signals on a DDR data bus with a less than ideal current return path can cause noise referred to as simultaneous switching noise (SSN).  To understand the effects of SSN, special I/O (Power-aware IBIS 5.0) and interconnect models (coupled signal, power, and ground) must be utilized by the analysis tools.  The IBIS 5.0 models must come from the memory controller or memory provider.  However, power-aware interconnect models are typically extracted from a completed design.
Design team challenge
This creates a challenge for design teams wanting to explore various strategies for understanding the impact of SSN on their future designs.  Once a design is fully routed, it may be too late to correct a problem and still meet a tight schedule.  To address this problem, the Allegro Sigrity SI Base and Options provides the ability to create example configurations quickly and then analyze those configurations using a variety of analysis techniques – from first order to detailed 3D extraction and simulation.
The following video provides an example of how the Allegro Sigrity SI Base lets you start with nothing and within minutes create sample designs that can be used for early analysis:
As the video suggests, design teams using Allegro can benefit from this early analysis by taking the working sample configurations and copying the module into a design under development.  The result will be a memory interface pre-validated to be DDR compliant from a power-aware perspective.
If you have any feedback on the value of integrated design and analysis technology, please let us know.
Team Allegro
Related stories:
Allegro Sigrity Makes its Debut at DesignCon 2013
What's Good About Allegro PCB Editor Net Groups? See for Yourself in 16.6!
What's Good About RF PCB and Agilent ADS Via Exchange? 16.6 Has Many New Enhancements!
