  3. BoardSurfers: Training Insights: Automating Artwork Configuration…
anandd
anandd
PCB Design Automation
Gerber file creation
PCB Editor Workflow
Allegro X PCB Editor
artwork
Automating PCB Artwork
artwork film workflow
artwork film generation
Cadence Allegro Training
Film Generation in PCB
film setup in Allegro X
BoardSurfers: Training Insights: Automating Artwork Configuration in PCB Editor
3 Nov 2025 • 3 minute read
In PCB design workflows, configuring artwork films is one of the final and essential steps before generating Gerber files for PCB fabrication. Each new design may require a fresh configuration of artwork films, especially if the stackup has changed. This process, while critical, can be repetitive and time-consuming.
With release 24.1 or later of Allegro X PCB Editor, you can automate this task using the Artwork Configuration feature available from the Config button in the Artwork Control dialog box. Use the feature to define the artwork setup once and then reuse it across multiple designs or share it with team members, thereby streamlining the workflow and reducing setup errors.
Let's explore how this feature simplifies the workflow and helps PCB designers save valuable time, improving efficiency and consistency across multiple designs.
Accessing the Artwork Configuration Dialog Box
To access the Artwork Configuration dialog box, follow these steps:
  1. Start PCB Editor.
  2. Choose Manufacture – Artwork. The Artwork Control Form dialog box appears.
  3. Click Config to open the Artwork Configuration dialog box.
Understanding the Artwork Configuration Dialog Box
The Artwork Configuration dialog box includes system-generated default film records for copper layers, such as External Conductor, Internal Conductor, Internal Plane, and Internal Negative Plane. These etch-based film records, available by default and representing the design stackup, cannot be deleted, ensuring a consistent and generic setup applicable to any design. The Fabrication Drill view auto-generates films for all drill stages. While these are system-generated, you may need to review and update the fabrication drill views based on the specific requirements of your design.
Custom layers, such as Soldermask, Solderpaste, Silkscreen, and Assembly Drawing Views, are user-defined film records. These can be modified or removed to match the design intent.
Configuring Artwork Films Categories
Once the configuration is complete and the film records are verified, you can close the Artwork Configuration dialog box and click Generate Films to create the artwork film records. If further customization is needed, the Class and Subclass options in the dialog box can be adjusted to allow precise control over the output for creating the required artwork films.
Learn More
For a deeper dive into automating and managing artwork film records, refer to the following videos from the Allegro PCB Editor Basic Techniques video channel:
  1. How to Automate the Film Record Generation in the Allegro X PCB Editor
  2. How to Modify, Save, and Reuse Artwork Film Record setup in the Allegro X PCB Editor.
 For additional information on the features of the Allegro X PCB Editor, enroll in the Allegro X PCB Editor Basic Techniques Training course on the Cadence ASK portal.
 You can become Cadence Certified once you complete the course.
Cadence Training Services now offers free Digital Badges for all popular online training courses. These badges indicate proficiency in a certain technology or skill and give you a way to validate your expertise to managers and potential employers. You can add the digital badge to your email signature or any social media channels, such as Facebook or LinkedIn, to highlight your expertise.
To find out more, see the blog post Take a Cadence Masterclass and Get a Badge. You might also be interested in the training Learning Map that guides you through recommended course flows, as well as tool experience and knowledge-level training modules. Find out how to get an account on the Cadence ASK portal.
An accelerated learning option is now available, which will help you learn Cadence technical content in the fastest, most effective way.
Before you begin the accelerated online course, take the pre-quiz to assess your current knowledge. This quiz lets you skip content you are already familiar with and helps you achieve your training goals more efficiently. For further guidance and explanations, refer to Accelerated Learning – The More You Know, the Faster You Go.
Subscribe to the Cadence training newsletter to be updated about upcoming training, webinars, and much more. If you have any questions about courses, schedules, online training, blended/virtual, or live training, contact us at Cadence Training.
