  3. Empowering Learning: New Learning – Cadence Allegro and…
Jasmine
Jasmine
Allegro Design Entry
Allegro 17.2
AMS simulator
OrCAD Capture
Capture CIS
Why Move Up to 17.2
Empowering Learning: New Learning – Cadence Allegro and OrCAD Release17.2-2016
26 Jul 2017 • 1 minute read
Interested in an easy-to-use, collaborative, and robust design-environment that reduces design cycle? Use, Cadence® Allegro® and OrCAD® release 17.2-2016.  Here are the 10 Top Reasons to Move Up to Allegro 17.2-2016 Release  This enables you to accelerate your PCB design cycle.
Get started immediately with the new release using the central page on https://support.cadence.com. It lists important links to Allegro and OrCAD 17.2-2016 documents. Visit the “one-stop shop" page to get all you need to install and use the release.
Visit the page - https://support.cadence.com/SPB172launch
These pages list What’s New, videos, application notes, migration guide, and other online help documents. In the left pane, select Getting Started for release-level information or select a product (for example, Allegro PCB Editor) for information about it.
Rigid-Flex : Rigid-Flex in Allegro® PCB Editor 17.2-2016
Enhanced Backdrill : Enhanced backdrill in Allegro® PCB Editor 17.2-2016
How to slide cline segments or vias using the "IX" and "IY" incremental commands
Allegro Design Entry HDL
PDF Publisher – Watermark Support  How to set up a watermark for PDF in Allegro® Design Entry HDL
PDF Publisher – PDF / A Generation :    How to publish ‘A’ compliant PDF (PDF/A) in Allegro® Design Entry HDL
Allegro Design Entry CIS (OrCAD Capture)
Export or convert a Capture design to ISCF
Exporting Intel Schematic Connectivity Format (ISCF) in OrCAD® Capture CIS
Generate intelligent PDFs of the schematic
How to generate intelligent PDFs of the schematic with version SPB 17.2 ?
Allegro AMS Simulator (PSpice)
Frequency Response Analysis (FRA) in PSpice -  Setting up and running Frequency Response Analysis (FRA) in PSpice
How can I run advanced analysis from my normal PSpice design? - Steps to add tolerances to run advanced analysis.
Visit the page - https://support.cadence.com/SPB172launch for more.
Contact us for any questions. Leave a comment in this blog post or use the Feedback / Like mechanism within https://support.cadence.com.
Happy New Learning!
~Jasmine
