  3. Cadence Online Support—Empowering Learning! New Learnings…
Jasmine
Jasmine
"PCB design"
application note
Cadence Online Support—Empowering Learning! New Learnings from June 2016
22 Jul 2016 • 2 minute read
Cadence Online Support Features
"You might also be interested in” Section
“You might also be interested in” section in Cadence Online Support (COS) section is present immediately under the document being displayed.
This provides links to additional material that might be of interest to you. The links are generated dynamically on the basis of the current document being read.
Rapid Adoption Kit (RAK)
Constraint Manager Xnet Setup and Configuration
This document guides you through the basic process of setting up Xnets in a high-speed design. The scope of this document is the setup of Xnets and is not a full design simulation scenario. This document guides you through the basic setup process.
PCB Editor - STEP Model Tutorial
This document outlines the processes and procedures required to setup and use STEP models inside Allegro PCB Editor. It covers:
  • STEP Model Support in PCB Editor
  • Mapping STEP Models in the Symbol Editor
  • STEP Model Mapping in PCB Editor
  • Mapping Mechanical STEP Models
  • Mapping a Mechanical STEP Model to a Board Drawing
Application Notes:
How to Visually Compare Layers From One SiP Design to Another?
At times you need to compare a layer of one SiP design with a layer of another design to compare the metal differences. For example, there could be variant designs where routing is slightly different to achieve specific impedance, inductance, resistances, or capacitance. By using the Batch Layer Compare feature, you can identify these differences.
Packaging Synchronization Checks for Reuse Blocks in Design Entry HDL
This application note describes new DE HDL checks introduced to address and verify synchronization status of reuse block schematics and the packager (PXL) block state files when working in a team-based hierarchical environment.
DML Library Reference and Management
The purpose of this application note is to review and inform users of features available to them when trying to manage their local DML libraries.
Front-to-Back System Co-Design Flow Guidelines
This application note provides system design flow guidelines for a team of designers. The goal is to establish a scalable, error-free, design-flow methodology that allows for concurrent system design development (schematic, board, and constraints) while maintaining design data integrity and synchronicity.
Videos
PDN Capacitor Additions for What-if Analysis in PowerSI
This video shows how to add capacitors to a PDN layout to perform what-if analysis in PowerSI.
Analyzing a Decap Configuration in the Allegro Sigrity PI Power Feasibiltiy Editor
The first order single node analysis in the Power Feasibility Editor makes it very easy to evaluate the usefulness of you decoupling capacitor scheme and try a variety of different scenarios..
Adding Termination in SystemExplorer
This video shows how to add terminations to a SystemExplorer simulation..
Training Bytes:
Self-learning videos to learn more on the tools can be seen from Training Bytes. New videos have been published for:
Allegro Design Entry HDL
Sigrity Power and Signal Integrity
Leave a comment below or make use of the feedback mechanism within Cadence Online Support.
Hope you find these knowledge resources useful.
Jasmine
