  3. Cadence OrCAD X and Allegro X 25.1 Is Now Available
AllegroReleaseTeam
AllegroReleaseTeam
System Capture
OrCAD X Capture
package designer
Allegro X PCB Editor
25.1
Topology Workbench
Allegro X Design Platform
Aurora
PCB Editor
OrCAD X OnCloud
OrCAD X Presto
OrCAD X
Sigrity
Pulse
allegro x
29 Oct 2025 • 4 minute read
The OrCAD X and Allegro X 25.1 release is now available from Cadence Downloads, delivering significant enhancements and new features. Here’s a summary of what's new:
Allegro X PCB and Package Design Solutions
  • Introduced Allegro X AI Advanced Substrate Router in Allegro X Package Designer for optimized routing of high-density single and multi-chip designs.
  • Added a positive mask option in the Cross-Section Editor to simplify the interpretation of mask layers.
  • Enhanced text management with OpenType fonts, including the Mooretronics symbol font, and added new Search, Reports, and Constraints panels for instant design information access.
  • Import pin delays from multiple sources, including Excel files, Constraint Compiler files, and existing pin delay formats.
  • Introduced a unified Differential Pair Automatic Setup dialog, consolidating all differential pair definition features.
  • Added Smart Search for properties and preferences, and a unified Exports dialog for managing data exports.
  • Recommend Topology Workbench for managing topology-based constraints.
  • Added new SKILL functions to extract design data and delivered significant performance improvements across design rule checks, placement, routing, shapes, In-Design Analysis, and 3D viewing.
  • Replaced 3D Design Viewer with 3DX Canvas within Allegro X Package Designer.
  • Install Allegro X PCB layout tools on up to five devices with a single-user license (also referred to as OnCloud licensing) for simplified license management.
Allegro X Pulse and Allegro EDM
  • Improved backup checkpoint creation performance by up to 3x.
  • Discontinued support for DE-HDL design flows in EDM.
Allegro X System Capture
  • Upgraded the system-level design workflow for complex multi-board designs, added cross-reference report generation, and enabled support for cells with duplicate names across libraries.
  • Integrated SnapMagic as a new component provider, streamlined electrical stress analysis workflows, and added separate dashboards for pre/post-layout Power Topology analysis.
  • Expanded Collaboration Mode to handle more CAD and library data types and enabled post-creation updates to library templates.
  • Design Entry HDL is replaced by superior capability within Allegro X System Capture.
OrCAD X Capture CIS
  • Install OrCAD X Capture on up to five devices with a single-user license (also referred to as OnCloud licensing) for simplified license management.
  • Enabled schematic design reviews with comments and markups and enhanced the Find and Replace functionality for part properties.
  • Allowed saving and loading of design templates (.dtp file) and enabled OnCloud license borrowing for offline use.
OrCAD X PCB Presto
  • Layout and canvas enhancements - Utilize OpenType fonts, including the Mooretronics symbol font, directly in the design canvas for improved text and symbol management.
  • Footprint Editing - Modify pad properties directly in the Property panel with a real-time preview of all changes, ensuring accuracy.
  • Constraint Management:
    • Automatically define differential pairs to accelerate the constraint management process.
  • Library Management - Extract libraries directly from existing designs for simplified reuse.
  • PCB Documentation - Enhance assembly documentation in LiveDoc with new callout shapes and customizable balloon leaders.
  • OrCAD X Cloud:
    • View, review, and manage markups for schematic and layout designs directly on the web for real-time collaboration.
    • Share workspaces via a direct web link to streamline stakeholder reviews.
  • In-Design Analysis - Perform Signal Integrity (SI) and Power Integrity (PI) analysis directly within the design canvas, powered by integrated Sigrity technology.
  • License Management - Install OrCAD X PCB Presto on up to five devices with a single-user license (also referred to as OnCloud licensing).
PSpice and PSpice Advanced Analysis
  • Expanded advanced modeling capabilities to include non-linear passive devices and memristors, and added support for GaN MOSFET models.
  • Added ISO 16750-2 automotive transient sources, enabled model sweeps with the .MODELSTEP command, and enhanced .MEASURE commands for complex expressions.
Sigrity X Aurora
  • DC Resistance Workflow : Introduced to compute DC resistance for power and ground nets.
  • Thermal Workflow : Now provides multi-die support.
  • Topology Extraction Workflow : Now enables topology-driven LayoutLink setup for multi-layout SI simulations directly from the layout.
  • Sigrity Aurora User Guide : New documentation available for SI/PI analysis workflows.
Sigrity X Topology Workbench
  • Subsystem Block : Introduced for creating hierarchical topologies, simplifying design, and enabling reuse.
  • SystemSI, SystemPI, and Celsius Enhancements :
    • Trace Editor: Edit the cross-hatch plane library to evaluate rigid-flex designs at the pre-layout stage.
    • Back-annotation: Export optimized parameters from Layout and Clarity 3D blocks to the Allegro X Constraint Manager.
    • Jitter Analysis: Include all Tx jitter from AMI models or Analysis Options in post-processing.
    • Compliance Kits: Added support for CEI-56G/112G MR, MIPI-D, and UCIe.
    • What-If Decap Models : Assign and sweep multiple decap models on one What-If block.
    • Optimality: Optimality Intelligence System Explorer is now supported in PDN Impedance and Power Ripple Analysis.
For details, refer to the README.pdf on Cadence Downloads. Stay tuned for blogs with deeper dives into these new features.
If you have questions or feedback, send them to pcbbloggers@cadence.com.
To receive release announcements such as this and other related information directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
Allegro Release Team
