  3. Cadence OrCAD X and Allegro X 26.1 Is Now Available
AllegroReleaseTeam
AllegroReleaseTeam
System Capture
26.1
OrCAD X Capture
Sigrity X
Allegro X PCB Editor
Topology Workbench
Allegro X Design Platform
Aurora
OrCAD X Presto
OrCAD X
Pulse
allegro x
22 Oct 2026 • 2 minute read
The Cadence OrCAD X and Allegro X 26.1 release is now available from Cadence Downloads, delivering significant enhancements across PCB design, package design, system-level design, simulation, and analysis workflows. Here is a summary of the key updates.
Allegro X PCB Editor and Allegro X APD
  • IPC-compliant footprint generation from an extensive library of standard templates, with support for automatic footprint regeneration.
  • Dynamic shape editing through the new Dynamic mode, enabling real-time shape updates and visual feedback during editing.
  • Component-level Design for Assembly (DFA) checks directly within the layout environment.
  • Enhancements to X AI routing technologies and new X AI Power/Ground Generator, improving routing productivity.
  • ECAD-MCAD co-design workflow enhancements that streamline collaboration workflows.
  • System-level design exploration in 3DX Canvas, with support for multiple boards and system connectivity in a unified 3D environment.
  • Simplified daisy-chain creation and editing for package designs.
  • SPICE-compatible RLGC models for advanced analysis workflows.
  • Parameterized structure creation and reuse for evaluating high-speed design alternatives.
Allegro X System Capture
  • System-level design enhancements, including support for 3D system exports and MCM board integration.
  • Integrated analysis enhancements in Layout Mode, including RLGC model extraction and LayoutLink-based reflection analysis workflows.
  • Reusable reliability parameter libraries for consistent application of validated reliability data across projects.
  • Preservation of Pulse custom variables in project archives to support design handoff and collaboration workflows.
  • Productivity improvements through schematic Minimap navigation and workspace window stacking.
  • Enhanced differential pair creation using Constraint Manager capabilities.
  • Improved pin delay import workflows with automatic data detection, validation, and pre-import review capabilities.
  • Enhanced module support and streamlined module management workflows for more efficient selection, management, and reuse of module instances.
  • Enhanced measurement capabilities for more accurate point-to-point and multi-segment distance measurements.
  • Customizable Heads-Up Display (HUD) and cursor settings that improve visibility, readability, and navigation.
  • Flexible pin renumbering capabilities that accelerate footprint creation and updates through support for multiple numbering patterns, numbering formats, and direct pin editing.
  • Net Override and Rule Set views that simplify constraint management by making it easier to identify overrides, enforce constraint inheritance, and manage net-specific design rules.
  • Improved visibility controls, streamlined layer navigation, and faster access to display views that enhance design productivity.
PSpice and PSpice Advanced Analysis
  • Persona-based simulation configuration for faster simulation setup and improved consistency across projects.
  • Additional component libraries from Murata and TAIYO YUDEN, expanding available simulation content.
  • Intelligent, condition-based model and subcircuit selection for more flexible and adaptable simulation workflows
  • Ambient temperature-based resistor derating for enhanced stress (smoke) analysis workflows.
  • Enhanced high-frequency resistor thermal noise modeling with quantum-corrected calculations.
  • Generic MATLAB and Tcl measurement functions for advanced custom analysis and verification workflows.
Sigrity X Aurora and Topology Workbench
  • Signal behavior and analysis improved across multiple connected PCB and package designs.
  • Multi-design reflection analysis enhanced with reusable System Configuration and LayoutLink files.
  • DDR measurement reporting optimized for next-generation memory technologies through support for LPDDR6 and HBM4.
  • Serial-link validation accelerated with multi-channel analysis, comprehensive channel characterization, and PCI Express® Gen 7 compliance support.
  • Waveform review and debug enhanced with advanced measurements, curve filtering, CSV export, enhanced result management, and the new Grid Curve Viewer for side-by-side waveform analysis.
  • Circuit simulation and analysis streamlined with direct generation of SPICE-compatible RLGC circuit models from layout structures in the IME workflow.
  • Complex system modeling simplified with support for IBIS-Electrical Module Description (EMD) models, linear buffer models, and automatic Broadband SPICE model extraction.
  • Signal and memory-interface validation streamlined with transient circuit simulation directly within Serial Link Analysis and support for simultaneous read/write cycle simulations.
For complete details, refer to the What's New documentation for release 26.1 and the accompanying README_CCR.txt file on the Cadence Downloads site.
If you have questions or feedback, send them to pcbbloggers@cadence.com.
To receive release announcements and related information directly in your mailbox, subscribe to the PCB Design blog.
Allegro Release Team
