  3. Follow Video-Embedded Troubleshooting Articles for Easier…
Jasmine
Jasmine
AMS simulator
OrCAD Capture
Follow Video-Embedded Troubleshooting Articles for Easier Debugging and Empowered Learning
18 Sep 2017 • 2 minute read
Finding a way out of situations is routine in today’s ever changing world—more so in the world of tech. Our problems range from trivial to critical. Mostly, people look for simple solutions that are easy to use. How sometimes a quick note can resolve a nagging problem! And a smart solution with a video simulating steps helps resolve issues even more quickly and satisfactorily.
This is exactly what we are now doing at Content Support Portal.  We have articles with videos showing relevant steps.
You never miss out any step while you are trying it in your designs.
Here is how it looks like:
Visit Content Support Portal for more such video-embedded articles on major products. For example, if you want to set up differential pairs in Constraint Manager so they are spaced 20 mils from other nets,  click here.
Some more examples of enhanced features elaborated in short videos within articles:
  • What are the improvements made to the docking panes in Allegro PCB Editor version 17.2?
  • How to customize toolbars in Allegro PCB Editor version 17.2?
  • Sliding cline segments or vias using the "IX" and "IY" incremental commands
  • Rotate groups of components and preserve their relationship to each other
Allegro Design Entry CIS (OrCAD Capture)
  • How to protect an Allegro Design Entry CIS (Capture CIS) design with a password
  • How can I force Capture to read custom configuration files (like allegro.cfg or Prefprop.txt)?
  • How to select a different license from within Capture and uncheck the default license
Allegro AMS Simulator (PSpice)
  • How to create the model for a Zener Diode
  • How can I run advanced analysis from my normal PSpice design?
We hope you find it useful and look forward to your feedback.
Leave a comment in this blogpost or use the Feedback / Like mechanism within Content Support Portal.
~Jasmine
