  3. How stable is your IC Package's PDN?
Maxwell86
Maxwell86
PDN
CDNLive
SPB
SPB16.2
SerDes
SSN
DDR3
21 Aug 2008 • Less than one minute read
There are three goals for a power a delivery network (PDN): sufficiency, efficiency, and stability.  Simultaneous switching of Gigahertz speed signals (i.e. DDR3) has made the stability of power a pressing issue in today’s designs. The Cadence SPB 16.2 release has addressed this challenge and will make analysis of the PDN a much easier job for IC Package Designers.
An automated flow fueled by Apache’s PakSi-E 3D field solver engine, enables the efficient extraction of coupled power, ground and signal nets.  The extracted models are then used in simulation to check that power and ground voltage variations caused by signals switching simultaneously are within specification.
This topic will be addressed at CDNLive! in Silicon Valley on September 9, so be sure to attend session 81CP2 - Package Design Flow for Multi-Gigabit Devices .
In the meantime, drop me a line if you have any questions or comments.
