  3. SI Methodology for Multi-Gigabit Serial Link Interfaces…
Sigrity
Sigrity
Serial link analysis
IBIS-AMI
PCIe
Signal Integrity
Backchannel
Sigrity
SI Methodology for Multi-Gigabit Serial Link Interfaces (7 of 8)
22 Feb 2018 • 2 minute read
Backchannel Training
Another capability related to equalization adaptation is backchannel training. Many high speed serial link protocols enable the SerDes receiver to evaluate the signal quality of training patterns sent by the transmitter, decide if it wants more or less equalization from the transmitter, communicate that request back to the transmitter, then receive another training pattern for evaluation. This process is repeated multiple times until the receiver is satisfied with the transmitter settings, then the actual data payload is transmitted with those preferred settings.
Figure 13 – Backchannel training
While the current IBIS standard does not support backchannel capability yet, there is a pending update to support this in IBIS with BIRD (Buffer Issue Resolution Document) 147, which will be incorporated into the next version of the IBIS specification.
Consider the following PCI Express Gen 4 example with and without the utilization of backchannel training.
Figure 14 – Initial channel simulation results
The initial result (in red) is shown without backchannel enabled. In this case, the transmitter’s AMI model self-optimizes its FFE tap coefficients based on the characteristics of the channel, while the receiver’s AMI model adaptation is done real-time, throughout the channel simulation. The second result (in green) is with backchannel training enabled, and clearly produces a more open eye. The interesting item to note is that if you look at the difference between the FFE tap coefficients used in both cases, you will see that the FFE coefficients have been turned down in the backchannel case. For example, this is how the pre-cursor tap coefficient adapted during the back-channel training:
Figure 15 – FFE adaptation during backchannel training
Here you can see that the pre-cursor tap coefficient starts out initially at an absolute value of almost 0.16, and then over the backchannel training process, gets turned down to the 0.14 range, based on the receiver’s discretion. This enables the receiver’s more advanced equalization functionality to do more of the “heavy lifting” and ultimately produce a better overall result. This shows the importance of enabling the backchannel communication in the channel simulation process, and developing AMI models that closely emulate the real-world behavior of the SerDes devices in actual hardware.
For more information on Backchannel Modeling, see our paper "Backchannel Modeling and Simulation Using Recent Enhancements to the IBIS Standard" presented at DesignCon 2018.
Next time > Automated Compliance Checking
Author Biography
 Ken Willis is a Product Engineering Architect focusing on SI solutions at Cadence Design Systems. He has nearly 30 years of experience in the modeling, analysis, design, and fabrication of high-speed digital circuits. Prior to Cadence, Ken held engineering, technical marketing, and management positions with the Tyco Printed Circuit Group, Compaq Computers, Sirocco Systems, Sycamore Networks, and Sigrity.
More about Signal Integrity:
How to Address the Challenges of Serial Link Design and Analysis
Why SerDes Signaling Is Trending Towards PAM Encoded Signals
How to Build an IBIS-AMI Model (Video)
