  3. Sigrity and Systems Analysis 2022.1 HF3 Release Now Ava…
SigrityReleaseTeam
SigrityReleaseTeam
Clarity 3D Layout
Sigrity XtractIM
Sigrity PowerDC
Clarity 3D Solver
T2B
Clarity 3D Workbench
Sigrity and Systems Analysis 2022.1 HF3 Release Now Available
9 Nov 2022 • 3 minute read
The Sigrity and Systems Analysis (SIGRITY/SYSANLS) 2022.1 HF3 release is now available for download at Cadence Downloads. For the list of CCRs fixed in this release, see the README.txt file in the installation hierarchy.
SIGRITY/SYSANLS 2022.1 HF3
Here is a list of some of the key updates in the SIGRITY/SYSANLS 2022.1 HF3 release: For more details about these and all the other new and enhanced features introduced in this release, refer to the following document: Sigrity Release Overview and Common Tools What's New.
  • Support for Parameter Optimization in Clarity 3D Workbench: Clarity 3D Workbench now supports parameter optimization that enables you to optimize your design parameters, thereby reducing the overall iterations, costs, and resources.
  • New Etching Options: Etching options have been added in the Options form in both Clarity 3D Layout and Clarity 3D Workbench. The etching options enable you to perform etching on traces, shapes, or pads on the selected power, ground, signal, or unnamed nets. By default, etching is performed only on traces for all the nets.
  • Bending Zone Preview in Clarity 3D Layout: You can now view the bending zone information for a rigid-flex design. When you open a rigid-flex design in Clarity 3D layout, a new pane, Flex Bending, is available that provides information, such as starting and ending coordinates of the bend line, the inner side of the bend, bend angle, and so on.
For detailed information, refer to the Clarity 3D Workbench User Guide.
Sigrity 2022.1 HF3
PowerDC
  • Export of Range Control Plots: PowerDC now supports the Export Range Ctrl Plots Only checkbox in the Options form for exclusively exporting the range control plots to the output report.
  • Support for Saving Report Files in a Folder: PowerDC now supports saving the report files to a specified path. To save the report files that are generated after the simulation is complete in a folder specified by you, select the Save report images check box in the Options form and click OK.
  • New Shortcut Menu for DC-DC Elements:  A new shortcut menu has been introduced for the DC-DC creation in PowerDC that enables you to perform various operations related to nodes.
For detailed information, refer to PowerDC User Guide on the Cadence Support portal.
T2B
  • Context-Sensitive Help for Accessing Documentation: Help buttons in the form of question marks (?) have been added to T2B that enable you to view the detailed documentation about a feature in the Cadence Help window.
For detailed information, refer to the T2B Quick Reference Guide on the Cadence Support portal.
XtractIM
  • Component Manager Enhancements: You can now split a component into multiple components using the Component Manager in XtractIM. This capability lets you analyze a small area of a large component by splitting it into multiple components.
  • Needle Array Netlist Enhancements: You can now generate a subcircuit model representative of a needle array with the help of a Tcl command in XtractIM. The number of evenly distributed sections created are based on the value of the input.
For detailed information, refer to XtractIM User Guide on the Cadence Support portal.
Sigrity Release Team
Please send questions and feedback to sigrity_rmt@cadence.com.
