  3. Sigrity and Systems Analysis 2022.1 Release Now Availab…
SigrityReleaseTeam
SigrityReleaseTeam
Celsius Thermal Solver
Sigrity PowerSI
Mesh Refinement
OrCAD/Allegro 17.4 (SPB174)
Sigrity SPEEDEM
Clarity 3D Solver
Layout Workbench
Sigrity and Systems Analysis 2022.1 Release Now Available
24 Feb 2022 • 7 minute read
The Sigrity and Systems Analysis (SIGRITY/SYSANLS) 2022.1 release is now available for download at Cadence Downloads. For the list of CCRs fixed in this release, see the README.txt file in the installation hierarchy.
SIGRITY/SYSANLS 2022.1
Here is a list of some of the key updates in the SIGRITY/SYSANLS 2022.1 release: For more details about these and all the other new and enhanced features introduced in this release, refer to the following document: Sigrity Release Overview and Common Tools What's New.
Platform Support Matrix Update
In the Sigrity/SYSANLS 2022.1 release, support for RHEL 6.5 (and later, up to RHEL 7.3), SLES 11, and Windows 2012 Server (all service packs) has been discontinued. The table below displays the supported platform matrix:
Platform
Linux x86
(64-bit)
Microsoft Windows
(64-bit)
Architecture X86_64 X86_64
Supported OS
RHEL 7.4 and later
RHEL 8
SLES 12
Windows 10
Windows 2016 Server (all service packs)
Windows 2019 Server
Early Announcement: PowerSI and Clarity Engines to Support Automated Extraction Directly from Allegro Canvas in March 2022
A new workflow will soon be integrated with Sigrity Aurora in the OrCAD® and Allegro® 17.4-2019 QIR4 [HF28 March 2022] release to enable greatly simplified and automated interconnect model extraction (IME). The PowerSI and Clarity engines have been enhanced in the Sigrity and Systems Analysis 2022.1 base release to facilitate this new workflow.
Windows users that are licensed to run Sigrity Aurora II and Sigrity PowerSI II and/or Clarity 3D Solver will benefit from this integration when the following two releases are installed together:
  • OrCAD® and Allegro® 17.4-2019 QIR4 [HF28 March 2022]
  • Sigrity and Systems Analysis 2022.1 base release
  • Viscoelastic Material Properties Added to the Material Manager: You can now define viscoelastic properties of materials to study the structural response of your design with respect to stress and temperature. In Celsius, viscoelastic properties are represented by the Prony series calculations, as per the following expression:
Where G0 is the instantaneous shear relaxation moduli, Gi is the Prony series coefficient, and τi is the relaxation time for each Prony component.
  • Temperature-Dependent Dissipation Curves Added: You can now define temperature-dependent dissipation curves in the Celsius Solid Objects Simulation for 3D Structures and Celsius Fluid Flow Simulation modules. You can then use this curve data when specifying power for the static 2D and 3D heat sources.
  • Plots Enhancements: The following improvements have been made in the simulation results plots in the Celsius Solid Objects Simulation for 3D Structures and Celsius Fluid Flow Simulation modules for improved usability
    • All curve items are now plotted in different colors
    • Curve results can now be exported to a .csv file using the Export CSV option in the context menu
    • The scale of the plot axis can now be updated by double-clicking the axis and specifying new values for the X and Y axis
  • Task Assistant Implemented for Solver Options Form: A new help tool called Task Assistant, has been implemented in the Solver Options form in the Celsius Fluid Flow Simulation module. Task Assistant provides a quick overview of the tasks in the context of the action you are currently performing. It provides help information for the possible "how to" questions that you would have in mind while setting up the solver options for a simulation run.
  • Sweep Parameter Enhancements: In the Celsius Solid Objects Simulation for 3D Structures and Celsius Fluid Flow Simulation modules, the parameterization support has been extended to include other objects in addition to boundary conditions and material properties. The objects and boundary conditions that support parameterization are: Static Power and Temperature, Heat Transfer Coefficient (HTC), VRM/Sink Patch, Component Thermal Models, Surface and Volume Seeding, and Simulation Options. In addition, the Celsius Fluid Flow Simulation module supports the parametrization of Flow resistance, Chamber and Chassis Attributes, Fan (construction and cooling) Properties, Mesh Refinement, and Liquid Cooling.
For detailed information, refer to Celsius Thermal Solver User Guide on the Cadence Support portal.
Clarity 3D Solver
  • New Meshing Algorithm Introduced: Clarity 3D Layout now supports a new meshing algorithm, LMesh. LMesh is much faster than XMesh and is specifically designed for layer-based structures (PCB, PKG, interposer/IC).
  • Area Ports Enhanced: In Clarity 3D Layout, area ports can now be defined as horizontal lumped gap ports or coaxial ports. You can now also specify the distance between the positive nodes. If the distance between the two positive nodes is within the specified value, only one of them is used to create the port.
  • Post-Processing GUI Developed in Clarity3DWorkbench for Better Visualization of the Field Quantities: For better and enhanced visualization of the field quantities, a new GUI is now available that enables you to perform operations, such as plotting on a slice, line, and points on the 3D objects and also plot multiple field quantities. All the capabilities from the legacy field plots have been transferred to the new post-processing GUI. The new post-processor can now handle large .R3D files and designs with ease and overcomes the GUI latency when changing the port or frequency, or performing any operation in the legacy flow.
  • Support for Wave Ports Added in Clarity 3D Workbench: Clarity 3D Workbench has been enhanced to support wave ports. A wave port represents the excitation from a semi-infinite waveguide whose cross-section is the same as the wave surface. It is more accurate than a lumped port because the excitation field pattern is calculated from the cross section. As a result, it is closer to the real excitation and does not introduce any additional parasitic effect.
  • 3D Component Updates: For the encrypted 3D Components the mesh and field results are now not visible for the hidden parts during post-processing in Clarity 3D Workbench. This helps vendor companies to protect their IP when sharing their components (such as 3D capacitors, 3D inductors, 3D connectors and off-the-shelf antennas) to hide the inner details of the design, but at the same time enables their customers to use the components and run the 3DEM simulations.
For detailed information, refer to Clarity 3D Layout User Guide and Clarity 3D Workbench User Guide on the Cadence Support portal.
Sigrity 2022.1
Sigrity SPEEDEM
  • S-parameter Simulation Methodology Enhanced : The S-parameter simulation methodology has been enhanced to reduce the run time. Depending upon the actual cases, performance improvement can be up as much as 50 percent.
  • Sparse SPICE Circuits Algorithm Enhanced: The algorithm used in solving sparse SPICE circuits is enhanced by the new multi-threading architecture and matrix partition solver. It can help to increase the simulation speed of sparse SPICE circuits by two to four times.
For detailed information, refer to SPEEDEM User Guide on the Cadence Support portal.
Layout Workbench Enhancements
  • Die Stack Functionality Added: Layout Workbench now supports the Die Stack functionality that lets you review and edit the die stacking information in a design. You can now view die stacking information, such as the attachment type, orientation, pad height, and placement sequence, in a design. In addition, this functionality helps you edit and view the thickness of the design on a real-time basis.
For detailed information, refer to SPD Layout User Guide on the Cadence Support portal.
Sigrity Release Team
Please send questions and feedback to sigrity_rmt@cadence.com.
