  3. System Analysis Knowledge Bytes: Sigrity X the Next-Generation…
deeptik
deeptik
Sigrity and Systems Analysis
Celsius Thermal Solver
SPEEDEM
XcitePI
Sigrity X
IBIS Modeling
Sigrity PowerSI
Power Integrity
Sigrity OptimizePI
IBIS-AMI
Signal Integrity
Sigrity SystemSI
Sigrity XtractIM
Sigrity PowerDC
Clarity 3D Solver
T2B
Allegro PCB Designer
System Analysis Knowledge Bytes: Sigrity X the Next-Generation Signal and Power Integrity Solution
8 Nov 2021 • 5 minute read
computational fluid dynamics news
The System Analysis Knowledge Bytes blog series explores the capabilities and potential of the System Analysis tools offered by Cadence®. In addition to providing insight into the useful features and enhancements in this area, this series aims to broadcast the views of different bloggers and experts, who share their knowledge and experience on all things related to System Analysis.
In 1965, Gordon Moore, while predicting the future of semiconductor industry, made an interesting observation that the number of transistors in a dense integrated circuit (IC) doubles every two years. Decades later we know that this prophecy, also known as Moore’s law, shaped many design innovations. However, as designs continue to shrink, their complexity is continuously increasing.
The challenges that design engineers face today are not only limited to single-board or single-package issues but also related to the entire multi-board system. The primary methodology to handle these design challenges is a system-level signal and power integrity (SI/PI) solution.
In its commitment to solve these system-level analysis problems with unprecedented speed and accuracy, Cadence has introduced Cadence® SigrityTM X, the next-generation signal and power integrity (SI/PI) solution. Sigrity X features new, powerful simulation engines for system-level analysis, and includes the innovative massively distributed architecture of Cadence ClarityTM 3D Solver.
Sigrity X Product Portfolio
Sigrity X includes a full set of tools for building system-level simulations, whether it is parallel bus analysis or PI analysis. The following figures provide an overview of the Sigrity X product portfolio:
Electronic Packaging Design
Sigrity X
IBIS Modeling
The Cadence Sigrity Advanced IBIS Modeling solution gives you the ability to create input/output (I/O) device models that are accurate, efficient, and easily distributable.
Under the Advanced IBIS Modeling solution, Sigrity X offers the Sigrity Transistor-to-Behavioral Model Conversion (T2B) solution that provides accurate full-bus simulation capabilities, and the Sigrity AMI Builder technology that models SerDes (Serializer/Deserializer) and memory interface devices.
Interconnect Extraction
Sigrity XcitePI Extraction can be used for design and verification of power delivery network (PDN) systems and high-speed I/O. It generates models of the chip's die redistribution layer (RDL) and interconnects between IO cells and connections to a package.
For detailed model generation, you have Sigrity PowerSI and Sigrity XtractIM technologies. If you need a more detailed model generation, Clarity 3D Solver is available to generate full-wave S-parameter models with unmatched speed and capacity.
Signal Integrity
For Signal Integrity, you have the Sigrity SystemSI technology for serial/parallel link analysis and the SPEEDEM technology for finite difference time-domain (FDTD) analysis.
Power Integrity
For performance/cost optimization and reliable power delivery, there are power integrity tools, such as Sigrity OptimizePI and Sigrity PowerDC.
Additionally, Sigrity X works in sync with Clarity 3D Solver and is tightly integrated with the Cadence Allegro® PCB Designer and Allegro Package Designer Plus implementation tools. The PCB and IC package designers can leverage this setup to incorporate end-to-end, multi-fabric, multi-board system analysis for SI/ PI signoff success.
Why Sigrity X?
Performance Improvements
Thanks to distributed computing, which is at the core of Sigrity X, you can address SI and PI problems much faster and iterate much more quickly, while maintaining the same trusted accuracy.
Sigrity engines that have previously been tested in VoltusTM IC Power Integrity Solution, Clarity 3D Solver, and CelsiusTM Thermal Solver have been re-architected in Sigrity X. The combination of re-architected engines that efficiently utilize the cores on a single machine coupled with the ability to distribute the simulation to two or more computers allows a large group of signals to simulate in a similar timeframe as the shortcut “worst-case” signal simulation.
The comparison table below summarizes the dramatic performance improvements in Sigrity PowerSI, PowerDC, XtractIM, and OptimizePI through distributed computing, code refactoring, and multi-threading computing:
Sigrity X
While all Sigrity tools report faster simulations when the number of cores remains consistent, there’s up to 10X performance improvement when more cores are added.
Streamlined User Interface
In Sigrity X, the Sigrity user interface has been revamped significantly and the tools in the product portfolio have been moved into a unified graphical user interface (GUI) for a common, consistent user experience. These tools support both Microsoft Windows and Linux operating systems.
Additionally, all workflows have been migrated into the same environment, called the Layout Workbench, enabling engineers to easily switch from one tool to another without the need to open each tool separately. Layout Workbench supports both light and dark themes, and many of the panels can be configured interchangeably.
In Sigrity X, all the data has been migrated into a single .spd file for all simulation types, making it much easier to copy or move simulation files between machines and to support multiple simulation types within the same file.
System Analysis
Signal Integrity Improvements
Allegro canvas uses Sigrity engines to provide traditional SI/PI analysis. Within the Allegro design canvas, Sigrity Aurora provides access to easy-to-use workflows for prototyping, topological extractions, crosstalk and reflection analysis, IR drop, impedance, coupling, and return path simulations. PCB Designers can screen designs and streamline the design process by catching issues early in the design cycle and editing the design without switching tools.
This wraps up our summary of Sigrity X features. Stay tuned as we explore other highlights from the world of Cadence Sigrity and Systems Analysis.
Happy Reading!
Deepti Kamal
  Datasheet
Sigrity X - Redefining Signal and Power Integrity
  Product Manual
Sigrity Release Overview and Common Tools What's New
  Blog
System Analysis Knowledge Bytes: Signal, Power, and Thermal Integrity using Layout Workbench
For more information on Cadence Sigrity and Systems Analysis products and services, visit www.cadence.com.
To receive notifications about the latest System Analysis Knowledge Bytes posts, enter your email address in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
