  3. BoardSurfers: Data Type Conversion in Allegro SKILL Pro…
Kirti Sikri
Kirti Sikri
Allegro SKILL Programming
Allegro X PCB Editor
BoardSurfers
Data Conversion
PCB Editor
23.1
allegro x
SKILL
BoardSurfers: Data Type Conversion in Allegro SKILL Programming
18 Apr 2024 • 4 minute read
 Data type conversion is a crucial aspect of programming that helps you handle data across different data types seamlessly. The SKILL language supports several data types, including integer and floating-point numbers, character strings, arrays, and a highly flexible linked list structure to represent data aggregates. Efficient conversion between different data types is essential for various Allegro SKILL tasks. Let's delve into how to perform these conversions and explore some essential functions and techniques.
Comparing Data Conversions
SKILL language offers automatic data conversion based on the context of usage. To understand this, let us compare the following two examples:
Example 1:
X = 1
Y = 2.0
X/Y = 0.5
Here, X is automatically converted to a float data type because of Y, resulting in a float type value.
Example 2:
X=1
Y=2
X/Y = 0
No conversion takes place here as both the variables are of the same data type, integer.
Allegro SKILL Functions for Data Type Conversions
Some SKILL functions that are useful for data type conversions are included in the following table:
Data Conversion Type Function to use
Integer to Float
float()
Example:
X = float(34)
Result:
X = 34.0
Float to Integer
int()
Example:
X = 2.9
Xint = int(X)
Result:
X = 2
Caution: Potential truncation issues with this operation.
String to Integer and Float
atoi() converts string to integer
Example:
X = atoi("10")
Result:
X = 10
atof() converts string to float
Example:
Y = atof("1.2e-12")
Result:
Y = 1.2e-12
Numeric Strings to Numbers
evalstring() numeric strings to numbers (integers or floats)
Example:
  • evalstring("10")
    Result: 10
  • evalstring("10.0")
    Result: 10.0
  • evalstring("1+2")
    Result: 3
NOTE: You must cautiously use the evalstring() function to convert numeric strings. Any error in providing data type to this function may lead to incorrect results.
For example: evalstring("10/2.") => 5.0
Integer to String
sprintf()with %d format directive
Example:
sprintf(str, " %d ", 2)
Result: "2"
sprint() converts integer 2 to a string "2" (in double quotes) and stores it in the variable str.
Float to String
sprintf() with %g format directive
Example:
sprintf(str, "%g", 1.2e-12)
Result: "1.2e-12"
sprintf() converts the floating point number into a string "1.2e-12" and stores it in the variable str.
Any Number to String
sprintf()with %n format directive
Example:
sprintf(str, "%n", 1.)
sprintf(nil, "%n",1)
Result:
sprintf() converts the integer or floating-point number (in the [-]ddd.ddd format) number to string.
Symbol to String
  • get_pname (s_arg): Returns the print name of a symbol as a string
  • symbolToString (s_symbolName): Converts a symbol to a string of the same name
Example:
The following functions convert the symbol name x to a string and save it to the variable y:
y=get_pname('x) => "x"
y=symbolToString('x) => "x"
String to Symbol
stringToSymbol() converts a string to a symbol
Example:
The following function converts a string to a symbol:
y=stringToSymbol("test")=> test
List to String
buildString() converts a list to a string
Example:
aList=list("R1" "R2" "R3") => ("R1" "R2" "R3")
buildString(aList ",") => "R1,R2,R3"
String to List
  • parseString() breaks a string into a list of substrings with break characters
Example:
parseString("R1 R2 R3\n" )
 =>("R1" "R2" "R3")
parseString() breaks a string into a list of substrings with specified break characters, which are indicated by an optional second argument
Example:
parseString( "Now is the time" ) => ("Now" "is" "the" "time")
The default break character is a space.
parseString( "prepend" "e" ) => ("pr" "p" "nd" )
  • axlStringRemoveSpaces strips leading or trailing whitespace from a string
Example:
axlStringRemoveSpaces(" a ")
Result: a
axlStringRemoveSpaces( '(" a " " b "))
Result: '(“a” “b”)
Conclusion
Understanding data type conversion is essential for effective Allegro SKILL programming. You can seamlessly convert different data types using the available functions and techniques. This ensures an efficient handling and processing of data in your Allegro SKILL scripts, helping you tackle complex design automation tasks.
For any feedback or topics you want us to include in our blogs, write to us at pcbbloggers@cadence.com.
Subscribe to stay updated about our upcoming blogs.
About BoardSurfers
The BoardSurfers series provides solutions to the various tasks related to the creation and management of PCB design using the Allegro platform products. The name and logo of this series are designed to resonate with the vision of making the design and manufacturing tasks enjoyable, just like surfing the waves. Regular, new blog posts by experts cover every aspect of the PCB design process, such as library management, schematic design, constraint management, stackup design, placement, routing, artwork, verification, and much more.
