  3. BoardSurfers: Training Insights: Improve Debugging Efficiency…
Jasmine
Jasmine
Cadence Online Support
RAK
inspectar
BoardSurfers: Training Insights: Improve Debugging Efficiency Using Procedures In inspectAR-Allegro Flow
12 Jul 2023 • 3 minute read
BoardSurfersDebugging a PCB from a bare schematic and board is a time-consuming task. Using the Augmented Reality (AR) Electronics Platform, inspectAR with the Allegro® PCB Editor flow vastly improves the efficiency of PCB procedural testing by addressing the issues more efficiently.
The inspectAR application helps you document the procedure (step-by-step instructions) that you need to perform on a manufactured PCB design directly in Allegro PCB Editor. A procedure, once created, can be rerun multiple times by any engineer using inspectAR. The feedback from the inspectAR engineer can be relayed to Allegro PCB Editor for review by the designer to close the loop.
InspectAR Procedures
A procedure in inspectAR is a list of steps, and each step can consist of several instructions. A step may contain the following information:
  • A set of 2D overlays that will be activated in inspectAR while running the procedure. An overlay guides the user about the visibility of a component or a net
  • Instructions from the layout engineer who wrote the procedure
  • A list of review comments from the engineer who runs the procedure in inspectAR
In many situations, such as powering up the board or routine debugging, a procedure is the preferred way to communicate with a PCB designer because it documents the processes and allows delegating tasks to others asynchronously, if required. Verifying the noise of a power supply is one such task. Power quality is critical for any engineering design, and most of the supplies designed with a certain operating noise level must be verified.
The task of debugging a board becomes simple provided you know where to connect the test and measurement equipment. To create a procedure, a designer needs to do the following:
  1. Open Allegro PCB Editor and select an inspectAR project
  2. Download the associated EDA artwork to create steps and add overlays to the procedure
  3. Create test instructions and add the appropriate overlays for that step
Example
  • Step 1 might include a safety check to ensure the working area is clear of hazards
  • Step 2 might include finding the correct test locations on the board for the power supply
  • Later steps would cover taking the measurements and documenting the results
A procedure can be created to document the results and analyze the review comments in Allegro PCB Editor. This approach is recommended when a procedure must be run to verify multiple copies of the same design.
Learn More
To learn the complete flow in detail, download the Create, Run, and Review Procedures with inspectAR Allegro Flow Rapid Adoption kit (RAK), which is accessible to all the customers with a Cadence Online Support (COS) account. You can also check out our Cadence training byte link, which is regularly updated with new training videos.
Cadence Application Engineers Himanshu Sahni and Shikhar Dwivedi have authored this RAK.
Cadence Training Services offers free Digital Badges for all popular online training courses. These badges indicate proficiency in a certain technology or skill and give you a way to validate your expertise to managers and potential employers. You can add the digital badge to your email signature or any social media channels, such as Facebook or LinkedIn, to highlight your expertise. To find out more, see the blog post Take a Cadence Masterclass and Get a Badge.
You might also be interested in the training Learning Map that guides you through recommended course flows as well as tool experience and knowledge-level training modules. To find information on how to get an account on the Cadence Learning and Support portal, see here.
Subscribe to the Cadence training newsletter to be updated about upcoming training, webinars, and much more. If you have any questions about courses, schedules, online training, blended/virtual live training, or public or onsite live training, reach out to us at Cadence Training.
