  3. Webinar: From Days to Hours: GPU-Accelerated 3D Electro…
MSATeam
MSATeam
GPU
Clarity 3D Solver
millennium
Webinar: From Days to Hours: GPU-Accelerated 3D Electromagnetics
18 Nov 2026 • 3 minute read
As package complexity and PCB interconnect density push the limits of traditional simulation, engineering teams are spending days, sometimes weeks, waiting for 3D full-wave electromagnetic (EM) results. The bottleneck isn't the mesh, nor is it the solver setup--it's compute resources. From Days to Hours: GPU Accelerated 3D Electromagnetics demonstrates how Cadence’s Clarity 3D Solver for PCB and package design changes that. Whether you're evaluating high-performance computing (HPC) infrastructure, planning your EDA roadmap, or simply tired of waiting on simulations, this webinar shows you what's now possible.
Signal integrity (SI) engineers, package designers, EDA infrastructure leads, and anyone running, or thinking about running, large-scale 3D EM simulations will glean insight into how the Clarity solver leverages graphical processing unit (GPU) acceleration to dramatically reduce simulation runtime on real production designs, from package extraction to large PCB SI analysis. Benchmark results across industry-representative cases are presented that show how adding GPUs compresses simulation time from days into hours.
Clarity 3D Solver Overview
The Cadence Clarity 3D Solver is Cadence’s industry-leading 3D EM simulation software tool for designing critical interconnects for PCBs, IC packages, and system on IC (SoIC) designs. The Clarity solver helps designers tackle the most complex electromagnetic (EM) challenges when designing systems for 5G, automotive, high-performance computing (HPC), and machine learning applications with gold-standard accuracy. Key features include 3D EM extraction and simulation, state-of-the-art distributed processing, and integration with all standard design platforms. Engineers benefit from unprecedented performance and capacity, gold-standard accuracy, and correlation with physical measurements. They are experiencing a 5-10X performance advantage over other 3D solvers, which are constrained by computing resources, require structure manipulation to reduce problem size, sacrifice accuracy when solving large structures, and lack seamless integration with CAD tools and support for cloud computing.
Clarity 3D Solver and Millennium M2000 Supercomputer
The Cadence Millennium M1 CFD Supercomputer, the industry’s first turnkey computational fluid dynamics (CFD) solution, overcomes accuracy and speed limitations with a combination of best-in-class GPU and resident CFD solvers. When combined with the Millennium M2000 supercomputer, Clarity 3D Solver provides domain-specific solution stacks for multiphysics, semiconductors, and data centers. Many different configurations and infrastructures are supported, and it will accelerate all Cadence tools across the board, including CFD-type simulations, EM simulations, 3D-IC simulations, and the digital twin for data center simulations, among others.
Clarity 3D Solver with GPU features the industry’s first FEM GPU solution, which is equivalent to 1,000+ CPU cores with Millennium, 100+ CPUs similar performance per GPU, and up to 75% energy efficiency vs. CPU hardware.
GPU-accelerated Clarity FEM delivers orders-of-magnitude faster turnaround than CPU-only solutions. The images below highlight Clarity’s GPU performance for PCB (top) and packages, interposers, and embedded multi-die interconnect bridge (EMIB) simulation.
Clarity Automated Channel Extraction (ACE) Technology
Clarity ACE technology addresses a critical industry need: Automating partitioning and channel extraction in large EM designs. Clarity ACE technology represents a significant advancement in EM simulation automation; by automating the partitioning and extraction of complex design channels, the ACE feature streamlines processes that were previously manual and error-prone. With ACE technology, engineers can assign multiple net groups, perform simultaneous cutouts, and serialize or parallelize the entire workflow. This enables rapid reuse and adaptation of simulation setups across multiple design iterations and layouts, greatly reducing setup and post-processing times.
Clarity ACE technology embedded within the Clarity FEM solver enables designers to partition and solve selected pieces of the design in parallel or in series. When leveraged with the Millennium supercomputer, GPU accelerated Clarity FEM analysis transforms multi-day full-board/package analysis into same-day workflows with Clarity 3D-EM signoff solution.
Conclusion
GPU-accelerated Clarity technology delivers faster turnaround for complex 3D EM analysis with benchmarks of +10X speedup. Accuracy is backed by physical measurements that combines 3D EM signoff analysis with measurement correlation.
In addition, Clarity on Millennium enables a 75% reduction in energy cost.
Clarity ACE technology provides a more automated channel-analysis workflow with automated setup, managed parallel solves, and aggregated results.
Learn more about the innovative new Clarity 3D Solver with GPU by viewing the on-demand webinar here.
