  3. What's Good About Allegro PCB Editor Highlight Nets Associated…
PCB Layout and routing
Allegro GUI
Allegro 16.6
PCB Editor
Layout
Grzenia
What's Good About Allegro PCB Editor Highlight Nets Associated with Component? It’s in the 16.6 Release!
24 Mar 2015 • Less than one minute read
With the 16.6 Allegro PCB Editor release, a simplified method to highlight or de-highlight all nets associated with a component is offered in all applications modes. Hover over a symbol(s), then use the RMB to access the ‘Highlight Associated Nets’ command. Nets assigned the DC Voltage property are ignored.
Here are the steps to accomplish highlighting nets:
  1. Using any one of the application modes, hover over a symbol.
  2. Use the RMB to access the Highlight associated nets command.
  3. Select a highlight pattern from the popup dialog.
  4. De-highlight all associated nets by hovering over the symbol, then RMB - Dehighlight associated nets.
If the nets are not highlighting, check to see if the ‘display_nohilitefont’ variable is set.
Please share your experiences with this new capability.
Jerry “GenPart” Grzenia
